12 volt accessory ports
Old Jun 1, 2007 | 10:39 PM
johnnychopper's Avatar
johnnychopper
Default 12 volt accessory ports
Has anyone tried to convert one or both of the 12v ports to accessory only? In other words, so they aren't hot all the time?
Old Jun 2, 2007 | 03:06 PM
157dB's Avatar
157dB
Cut & Paste Expert
Default RE: 12 volt accessory ports
Nope, but it can be done. Any electrical knowhow on your end?
I have the factory electrical diagrams. Need the wire colors?
What year model, body style, GT V6 vert?
Old Jun 2, 2007 | 04:12 PM
johnnychopper
Yes, I have excellent technical ability. I have found the fuse in the engine compartment for the outlet. I was going to remove the fuse, and feed the outlet with a switched source within the same panel, but everything is hot all the time with the exception of three that are labeled "engine 1, 2,and 3." I did not want to mess with those. I have an '07 GT convertible.[/align][/align]me9er@aol.com[/align]
Old Jun 2, 2007 | 04:28 PM
157dB's Avatar
157dB
Cut & Paste Expert
OK, I am at work now. Let me get to the electrical diagrams when I get around
the house and get back to you. I know that the fuse panel in the engine compartment
is hot all the time for every fuse out there. Its the power distribution box. You will
need to go to the SJB located on the passengers side floorboard under the kick
panel access plate for key off power. Do you want start+run, run+acc, etc?
Old Jun 2, 2007 | 05:28 PM
johnnychopper
Accessory and run. I found a fuse for the mirror--not the power mirrors, I think it was for the auto-dim. It is hot when I need it to be. I used it for my nuvi. I can use that again, but I need access to the hot wire of the dash 12v without taking apart the dash. I guess that is where your wiring diagrams will help. Hopefully itroutes somewhere near the interior fuse panel. Thanks so much for the help.[/align]
Old Jun 3, 2007 | 04:52 PM
157dB's Avatar
157dB
Cut & Paste Expert
OK I found where the wire runs. The bundle comes thru the firewall
via a big rubber gromet above the passengers side floor mat.
From there it splits in 2 or 3 directions. You want the bundle
that runs right above the floor mat horizontalfrom right to left
towards the center dash where the cigar lighter is.
Inside this bundle is the power wire for the cigar lighter.
It is a 16 guage wire and probably the biggest in the bundle.
Carefully untape the bundle and look for the biggest wire.
If you have heated seats that is a different matter and get back
to me and I will get you the specific color of the wire.
Old Jun 5, 2007 | 03:12 AM
157dB's Avatar
157dB
Cut & Paste Expert
OK, I was wrong. Wrong power point.
That was the console power point. You
want the big connector between the SJB
and the passengers side door jamb. You
will have to remove the door sill and kick
panel to gain access. Its the big 16 guage
LiteBlue/White wire. The power flows up thru
the connector. This is for the dash mounted
power outlet.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Dokilar
15
Oct 16, 2015 08:13 PM
Urambo Tauro
Oct 5, 2015 09:37 PM
Dathan
Oct 5, 2015 05:52 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
