MMR Intake installation
Old Dec 30, 2004 | 03:14 PM
96GTponyup's Avatar
96GTponyup
Default MMR Intake installation
I recently installed the MMR Inake on my 05 GT and it says to remove the little filter inside the intake tubing in order to get max performance. I noticed that if you do remove it there is not a way to reinstall it.
My question is....Do you think by removing it there will be a chance that somthing could get sucked up into the intake causing damage and if I dont remove it will the cold air kit even work well?
Old Dec 30, 2004 | 05:18 PM
2005RedGT's Avatar
2005RedGT
Default RE: MMR Intake installation
You wont have any problems with junk being sucked into the system. That piece is used for emissions control and at thsi point, noone is having any issues with its removal. I would recommend you keep it for use later - if needed.
-Bryan
Old Dec 30, 2004 | 05:23 PM
Evil Sephiroth's Avatar
Evil Sephiroth
If you still can Return your MMR Intake!!!!!!!
When they Dynoed my Car they did it with and without the intake, They said it Added NO HP whatsoever. Its a waste of money, Id return mine if i could.
Old Dec 30, 2004 | 06:10 PM
2005RedGT's Avatar
2005RedGT
Hey evil, then your tuner is an idiot and dont go back. I got 18hp out of mine. BUT since it is a TUNER who does it, they do have to tune it - for example: the A/F ratio has to be changed.
I am sure your response will be that "he knows his stuff". Thats cool, but I have first hand watched the same tuner tune a few 05 with the MMR and get about the same results.
my 2 cents
-Bryan
Old Dec 31, 2004 | 12:44 AM
Evil Sephiroth
They Tuned it afterwords, and I didnt believe it at first either, but they said if there were any increases it was minimal. Yes its a Very acredited shop I goto. Its a Division of Fords and have very smart people working there! but In any way I hope your right!!
Old Dec 31, 2004 | 05:12 AM
bobby's Avatar
bobby
is it an intake or a cold air itnake? cold air intake im assuming?/? thanks!
Old Dec 31, 2004 | 08:40 AM
96GTponyup's Avatar
96GTponyup
Are you able to replace it once it is removed? It looks to me like you cannot. Also, do I have to get my car tuned now that I have added this piece in order to get a gain in HP from it?
ORIGINAL: 2005RedGT
-Bryan
Old Dec 31, 2004 | 09:49 AM
2005RedGT's Avatar
2005RedGT
Yes, you can put it back in - just be careful taking it our so that it is not damaged. You can get a small increate 4-7 hp (more like 4 hp) if you take it out and you wont need a tune for that. the computer compensates for it.
-Bryan
Old Dec 31, 2004 | 09:59 AM
96GTponyup's Avatar
96GTponyup
What did you use to take it out? Also, my check engine light came on. Did you have to get the cide erased or did just erase itself in time?
ORIGINAL: 2005RedGT
-Bryan
Old Dec 31, 2004 | 10:06 AM
2005RedGT's Avatar
2005RedGT
I took mine out wiht a pair of pliers and some elbow grease. After about 200 miles the light went off. A week later I got my second tune anywho
-Bryan
