webelectricproducts.com
Need a little help, I ordered the splice kit for these guys about 3 weeks ago. It took longer than I thought to install it but it was running good. Well THe other day I had a bulb burn out and changed it today, it was the middle bulb, I pulled the old and installed the new, when I tested to make sure everything was working the inner bulb will not work with only the lights on, when the hazards, brake or turn signal is on it works but just not when the lights are on.
To clear it up everything works but the inner when the lights are turned on.
I have rewired everything and no luck, anyone ran into this? I called to get help earlier but, shocker, no one answered.
I'm out of guesses!
I'm out of guesses!
I wired this Web electronics kit. Did you check the inside bulb for both filiments, both dims (lights) and brights (brakes). Also if I remember correctly you had to push a wire through on the inside bulb to connect to the brights. I would check this connection. If one side works and the other doesn't, I would cross refference the side working to the side that is not, it should be apparent what is causing the problem. I know the frustrations that can occur when wiring. Something could have been pulled loose when installing the bulb, check wire nuts ect,.
