Installing stripes tomorrow any tips?(Pics installed)
Old Jun 12, 2007 | 01:30 AM
moe07's Avatar
moe07
Default Installing stripes tomorrow any tips?(Pics installed)
Stripe kit arrived today and i am going to install themtomorrow, any tips would be great because i have never done anything like this before. Thanks in advance for any help.
Old Jun 12, 2007 | 01:51 AM
laredotexas's Avatar
laredotexas
Default RE: Installing stripes tomorrow any tips?
my tip would be to have someone that has done it before do it.. they should be many local shops that do decals with some vehicle back ground.. [sm=signs003.gif]
Old Jun 12, 2007 | 01:54 AM
swoosh's Avatar
swoosh
Take your time installing them, and even more careful on the front and rear bumpers, the pieces do not go on nearly as easy as the hood and roof. Also, when installing on the hood, make sure to have the windsheild-washer nozzles aligned correctly over the holes.
It's not rocket science, but having another person helping will be a benefit (in terms of peelingthe stripe off the backing as well asholding teh stripe while you spray down thepart of the caryou're applying it to
Old Jun 12, 2007 | 01:58 AM
moe07's Avatar
moe07
what did you use to spray the car with? I have the instructions but it doesn't say what to use. most of the instructions are for dry application.
Old Jun 12, 2007 | 02:40 AM
05gtdriver's Avatar
05gtdriver
You need an alcohol/soap mixture with slightly warm water(at least I used it a little warm) in a 20 oz spray bottle(old Windex bottle works well). Take your time, used plenty of solution and let each stripe dry before removing the paper backing(not to be confused with the wax paper, which comes off first). Letting it dry before applying the following piece is what consumes so much time(I had the car done at a tint shop, but I put on the front bumper stripes afterward because I ruined the first set which prompted me to have a pro do the remainder of the stripes, Rob at BSM was great at getting me a replacement front bumper set ASAP). Good luck, and post after you're finished!
Old Jun 12, 2007 | 02:49 AM
TxLonghorn's Avatar
TxLonghorn
Loosen the hood scoop. There are 4 bolts holding it down under the hood, if it is loose you can slide the stripes under it so much easier. Here are the instructions for the Baltimore Street Mods kit- http://www.baltimorestreetmods.com/i...&chapter=0 They say to use a solution of 20oz water, 1/4 teaspoon of liquid dish soap and 1/2 teaspoon of rubbing alcohol. I don't know what kit you have, but I assume the application would be similar.
Old Jun 12, 2007 | 03:06 AM
Jed's Avatar
Jed
I would ratherpay someone to install them just my opinion.But good luck[/align]
Old Jun 12, 2007 | 03:22 AM
moe07's Avatar
moe07
I'm not scared lol. I think i can handle it. if i mess up then i will have some one do it.txlonghorn thanks for the instructions they are better than the ones i have. i will post pic's when done.
Old Jun 12, 2007 | 03:32 AM
brendend's Avatar
brendend
take your time! i saw a guy who rushed putting them on and it looked horrible!! just take your time and follow the instrutions and youll be fine. or take it somewhere
Old Jun 12, 2007 | 04:07 AM
FordDude's Avatar
FordDude
ORIGINAL: TxLonghorn
Thanks for the link TxLonghorn. I am putting some rocker panel stripes on my Mustang soon and this thread applies. fd
