dash lights
Old Jun 12, 2007 | 08:46 AM
urnamethere's Avatar
urnamethere
Default dash lights
i have a base model 05 v6, the lights on the dash light up white when my headlights are off, once i turn them on the dash switches from white to green, is there a way to make it so that it stays white even when the headlights are on? i dont have the mycolor feature by the way
Old Jun 12, 2007 | 09:15 AM
dirtydeedsinc's Avatar
dirtydeedsinc
Default RE: dash lights
I think you need the Mycolor to do that. The dash lights come on without the headlights so you can see the gauges better because of how recessed the gauges are.
Old Jun 12, 2007 | 11:55 AM
Drop Top 06's Avatar
Drop Top 06
Your choices are to have it green when you drive with the lights on, or to drive with your lights off. I do not recommend driving in the dark without lights!
Old Jun 12, 2007 | 11:58 AM
LegallyTorchRED's Avatar
LegallyTorchRED
You need to take the wire that runs the gages on white, and apply it / jump it to the side of the headlight switch that runs the green. Should be a very easy thing to do.
Old Jun 12, 2007 | 02:55 PM
urnamethere
ORIGINAL: LegallyTorchRED
does anyone know what wires those would be or is it something i may have to fumble around with?
Old Jun 12, 2007 | 03:55 PM
Sticky Mustang's Avatar
Sticky Mustang
mine lights up blue in the day time, and a brighter blue like a baby blue at night
Old Jun 12, 2007 | 08:52 PM
157dB's Avatar
157dB
Cut & Paste Expert
LeagallyTorchRed:
"You need to take the wire that runs the gages on white, and apply it / jump it to the side of the headlight switch that runs the green. Should be a very easy thing to do. "
No its not a very easy thing to do. The cluster communicates via ethernet
and the headlight switch talks to the SJB which in turn talks to the cluster
and the cluster then changes colors. No wires from the headlight switch
to the cluster directly. Remove your cluster and attack the "problem"
at the actual lights. They will have to be changed to the desired color.
A LOT of trouble cause you dont like them green. Shoulda got the
my color optio if it bugs you sooo much. You could hijack the data
on the ethernet between the SJB and clusterand manipulate it at that level. LOL!
Not Laughing Out Loud but Lots Of Luck.
Old Apr 14, 2008 | 09:51 PM
22Stang08's Avatar
22Stang08
It's a shame its not an easy fix...I really like the white also.
folivier
Oct 2, 2015 05:34 AM
jc409
Convertible Tech
Sep 26, 2015 08:28 AM
Sep 25, 2015 09:06 AM
accarter
Sep 21, 2015 11:56 PM
2015Ecoboost
Sep 17, 2015 01:48 PM
