KOOKS help???
Old Jun 17, 2007 | 09:27 PM
S2Charlie's Avatar
S2Charlie
Default KOOKS help???
I recently purchased the KOOKS full exhaust kit from Brenspeed. They forgot to ask whether I had a manual or automatic, but when I fould out the only MAJOR difference was the amount of 02 sensor extensions, I didn't really mind, and they sent them next-day-air, what a good company... now I'm starting to think the 02 sensor connections may have been different also.
ANYWAY
I get this weird vibrating noise when I accellerate to about 2-2500 rpm's. Slow accelleration doesn't do it but moderate to WOT does. I thought that maybe the 02 sensors on the cats were hitting the heat shields but I don't think the Exhaust moves an inch (amount of clearance I have) from moderate throttling. The car doesn't do it in neutral only when the tranny is engaged. Any help pn this would be GREATLY appreciated. The noise is annoying the S*** outta me and if I bring it to Ford, I'm pretty sure they're gonna charge me b/c it's more than likely related to the exhaust. I can't remove the heat shield for obvious reasons, but I bent it a little and it didn't help, so I doubt that was the problem.
Old Jun 17, 2007 | 09:56 PM
luv2cheat's Avatar
luv2cheat
Default RE: KOOKS help???
I had a bent hanger on the x-pipe that was rubbing the trans crossmember. You might ck that??
Old Jun 17, 2007 | 10:39 PM
TrIpOd's Avatar
TrIpOd
is it a rattle or does your car start vibrating vigorously?
Old Jun 18, 2007 | 01:48 AM
S2Charlie's Avatar
S2Charlie
OMG... the car doesn't vibrate... it's just a noise that is a MAJOR P.I.T.A.! The little things bother me and I'm too poor to pay others to worry about them or get other means or transportation. So just a noise.
Old Jan 23, 2008 | 08:18 PM
Larmo's Avatar
Larmo
Did you fix this? What was the issue?
Old Jan 23, 2008 | 10:20 PM
Pwny's Avatar
Pwny
Its the x-pipe.
X-pipes have some inherant property about them that causes a mild vibration in that RPM range.
Old Jan 24, 2008 | 04:23 PM
S2Charlie's Avatar
S2Charlie
RESOLVED... It was an exhaust hangar.... I had realign it and bolt it in slightly differently... It was rocking and hitting a tranny crossbar bolt.
Old Jan 24, 2008 | 06:07 PM
navyscott's Avatar
navyscott
So other than the O2 extensions, the MT and AT setups are the same?
Old Jan 24, 2008 | 09:35 PM
S2Charlie's Avatar
S2Charlie
Yes... except the hangars are in different spots so you wouldn't have the problem I had. If you're aware of it during the install, it can be avoided
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
kevans79@yahoo.com
Aug 18, 2015 09:01 PM
texashotrods
64
May 4, 2009 01:37 PM
David_K
Mar 27, 2006 04:07 PM
