slp problem
Old Jun 25, 2007 | 04:28 PM
eddieval5's Avatar
eddieval5
Default slp problem
i just got my slp loudmouths in this morning and when i try to bolt on the clamps they dont tighten up..the exhaust pipe and the axle pipe dont tighten up even though ive tight the bolt as far as it will go...
Old Jun 25, 2007 | 04:30 PM
VerginaStang's Avatar
VerginaStang
Default RE: slp problem
ORIGINAL: eddieval5
Uhmmm please explain that a little better. maybe you stripped the bolts?
Old Jun 25, 2007 | 04:33 PM
TrIpOd's Avatar
TrIpOd
sounds like you stripped the bolts or your weak.
eddieval5's Avatar
eddieval5
the clamps that came with the slps will not tighten the axle pipe and the slp exhaust pipe all they way..they are loose even though ive thighten the clamp as far as theyll go...
Old Jun 25, 2007 | 04:38 PM
TrIpOd's Avatar
TrIpOd
ORIGINAL: eddieval5
so use the stock clamps
Old Jun 25, 2007 | 04:43 PM
eddieval5's Avatar
eddieval5
how do you get them off the stock ones..
Old Jun 25, 2007 | 05:40 PM
TrIpOd's Avatar
TrIpOd
ORIGINAL: eddieval5
wd-40 and a hammer
Old Jun 25, 2007 | 05:53 PM
stangdude81's Avatar
stangdude81
my stock ones are spot welded on to the stock mufflers, you'd have to drill that spot weld out.
Old Jun 25, 2007 | 06:09 PM
TrIpOd's Avatar
TrIpOd
ORIGINAL: stangdude81
i have an 05 but mine slipped right off with no trouble.
Old Jun 25, 2007 | 06:27 PM
eddieval5's Avatar
eddieval5
yea mine are spot welded..thanks..got em on..
