No AC???
Old Jun 25, 2007 | 09:59 PM
Stage4's Avatar
Stage4
Default No AC???
i can't figure out why my AC won't work. I put in a new motor a few months ago (i.e. AC was disconnected) and had it recharged afterwards with no problem. After a few weeks it stopped working, so i tried to recharge it and it showed plenty of pressure. It doesn't sound like the compressor is coming on? i can't hear anything change when i turn the switch on or off. Thoughts?
Old Jun 25, 2007 | 10:29 PM
hammeron's Avatar
hammeron
Default RE: No AC???
since i'm an electronics guy, i would start with
the fuses and wiring
a volt/ohm meter comes in handy at times like this
dcottrell6's Avatar
dcottrell6
It might not be the case but you should have the climate control module checked.
Old Jun 26, 2007 | 05:39 PM
Reco's Avatar
Reco
I'm having major problems with the AC in my 07 GT. Its been to the dealer 4x already. What makes it a extra pain in the *** is that its intermitent. The AC can work for 3 days, then the compresser wont turn on the next day. Last time they replaced the compressor and the condensor, that worked for about a day. Very frustrating since I really love the car minusthis issue, it has excactly everything I wanted. sigh, oh well.
Old Jun 26, 2007 | 06:04 PM
DeStonn's Avatar
DeStonn
actuator switch maybe. if youre looking at the radiator look to the right and down. happened to me when I had my cams installed.
Old Jun 26, 2007 | 06:36 PM
157dB's Avatar
157dB
Cut & Paste Expert
Is the green led indicator comming on when you
cycle the AC switch? Does the AC work when
the defroster is selected? The SJB controls the AC.[&o]
Old Jun 26, 2007 | 07:16 PM
PROMETHEUS PRIME's Avatar
PROMETHEUS PRIME
Try putting a jumper wire across the pressure switches. Then see if the clutch on the compressor engages with everything on.Then you'll know if it's an electrical or freeon concern.
Old Jun 26, 2007 | 07:27 PM
TrIpOd's Avatar
TrIpOd
i'd bring it to ford. have them deal with it.
Old Jun 26, 2007 | 07:34 PM
torch red's Avatar
torch red
Yea..lots of TSB on the AC..mine wasnt working either...they said something was blocked...
They fixed it..Take it to the dealer..
Old Jun 26, 2007 | 07:45 PM
Derf00's Avatar
Derf00
Gentleman's Relish
ORIGINAL: Stage4
Any air that got into the system would cause it to corrode internally.
Is the a/c clutch engaging when the A/C is on? The center of the a/c unit should spin when you turn it 'On' if not, could be a number of thing like the clutch switch, a/c switch, low pressure switch, etc.
