Conflicting info from Eibach
Old Jun 27, 2007 | 11:23 AM
MachRanger's Avatar
MachRanger
Default Conflicting info from Eibach
So I ordered a Pro-Kit spring set for my '06 GT and I've beenreading inthe forum that I might need an alignment kit that brings the camber back out. I called Eibach and the tech told me that I wouldn't need it if the car isn't lowered below 1.5".But the installation instructions say that IDO need it. Now what? Anybody here lower their car without the alignment kit? Need some help...thanks!
Old Jun 27, 2007 | 11:32 AM
mightymouse's Avatar
mightymouse
Default RE: Conflicting info from Eibach
if the car is lowered the front wheel camber will be in the negitive. Now it's not off by much but you will see that the inside of the tires will ware faster than the out side. with my past experance i liked the camber that way because i just love to push my cars in the corners. you can offset the ware problem with a set of Nito Neogen tires they are made for lowered cars runing negitive camber. or you can buy some camber plates and have the camber adjusted back toOEM settings.
Old Jun 27, 2007 | 11:41 AM
WhoMe's Avatar
WhoMe
The camber bolts are only 40 bucks. Even if the drop doesnt bring the camber very far out of spec its worth the small expense.
baddog671
Jul 26, 2016 01:20 PM
folivier
Tennessee Regional Chapter
Oct 2, 2015 05:32 AM
RCS02v6
Sep 29, 2015 01:46 PM
junior04
Sep 28, 2015 10:53 AM
GLOCKer
Sep 28, 2015 07:36 AM
