adj vs non-adj LCA
Old Jul 2, 2007 | 02:47 PM
cnapsys's Avatar
cnapsys
Default adj vs non-adj LCA
what's the benefit of one over the other?
which one should I go with?
Old Jul 2, 2007 | 02:53 PM
Menace's Avatar
Menace
Default RE: adj vs non-adj LCA
If you plan on doing things to your suspension that alter its geometry, you're going to need Adjustables to correct anything, or to further adjustment. (Lowering, etc.)
I have solid LCAs, but I'm going to go with an Adjustable UCA when I get a 1pc Driveshaft.
Old Jul 2, 2007 | 03:03 PM
Stkjock's Avatar
Stkjock
Retired Mod
+1 either the UCA or LCA should be adjustable to adjust your pinion angle if needed.
Old Jul 2, 2007 | 03:12 PM
howarmat's Avatar
howarmat
s197 Junkie
search for a couple threads by CrazyAl....you will find everything you need to know about suspension.
Old Jul 2, 2007 | 03:51 PM
cnapsys's Avatar
cnapsys
ok... so after trying the search feature here's a setup i found:
Steeda Ultralite Springs
Toicko D-specs
BMR Adjustable street LCAs
BMR LCA relocation brackets
BMR Adjsutable panhard bar
BMR Panhard bar brace
BMR rear sway bar
BMR Adj camber bolts
what do you guys think?
Old Jul 2, 2007 | 04:14 PM
TrIpOd's Avatar
TrIpOd
ORIGINAL: cnapsys
Toicko D-specs
BMR rear sway bar
thats a very good setup. BMR makes the best parts IMO. although I would reccomend the steeda rear sway bar, the BMR fits a little strange. the steeda is actually cheaper and constructed to fitbetter.
Old Jul 2, 2007 | 05:27 PM
JayFi's Avatar
JayFi
ORIGINAL: TrIpOd
ORIGINAL: cnapsys
Toicko D-specs
BMR rear sway bar
That is exactly the setup that I have sitting in my dining room waiting to be installed. The last piece in the puzzle is the d-specs, which should be arriving today.
Old Jul 2, 2007 | 05:40 PM
torch red's Avatar
torch red
I have BMR everything..No issues no problems..car handles amazing..
UCA and mount
ADJ. LCA and Brackets
Springs
Adj..Panhard and sway bar and .STB
D-specs..
Old Jul 2, 2007 | 09:24 PM
cnapsys's Avatar
cnapsys
now the hard part...
where to buy them from?
anyone? any links on good deals?
Old Jul 2, 2007 | 09:35 PM
jerjan's Avatar
jerjan
Awesome Set-up, you will lovethe combination of those parts!
ORIGINAL: cnapsys
Toicko D-specs
BMR rear sway bar
