Still getting misfires, PLEASE HELP!!!
Old Jul 3, 2007 | 06:39 PM
allfyre's Avatar
allfyre
Default Still getting misfires, PLEASE HELP!!!
I installed my Steeda UDPs on Saturday and ever since then I've been getting misfires. I really don't know what to do about it, I can't really think of any reason why the pullies would have caused it but it was fine before and after the installl I started having problems.
AFAICT the pulleys are in right and the car seems to run fine but every once in a while it starts throwing codes.
Anyone have any idea what might be causing this? Could I have possibly damaged my MAF meter and if so could this be the cause? Should I take out some timing, would that help? I don't know but I'm going to the track on Thursday so any help would be greatly appreciated.
Thank you all.
Old Jul 3, 2007 | 06:41 PM
mightymouse's Avatar
mightymouse
Default RE: Still getting misfires, PLEASE HELP!!!
Did you retune after the install?
Old Jul 3, 2007 | 06:43 PM
TrIpOd's Avatar
TrIpOd
take it to steeda, ford or someone who knows about UDPs. without anyone actually seeing your car, its going to be difficult to solve the problem.
EDIT: a retune is not needed for udps ^^^
Old Jul 3, 2007 | 06:45 PM
hammeron's Avatar
hammeron
it's unlikely that you damaged the MAF itself and
more likely that it could be a wire issue. check the
MAF connector and look closely at the wires and if they may
be loose or damaged in any way.....
Old Jul 3, 2007 | 06:47 PM
mightymouse
I just got off the phone with them and thats what they said. no need to retune.
Old Jul 3, 2007 | 06:48 PM
allfyre's Avatar
allfyre
All the wires seem connected, as for a tune, I was under the impression that the UDP's didn't require one. While I was doing the install I cleaned the filter on my CAI and it's possible that there was still some moisture in there when I put it back on, but everything would be dry as a bone by now.
The only place around here I could really take it would be to the dealer, and they probably won't even look at it until next week because this place is ghetto.
Old Jul 3, 2007 | 06:56 PM
A_J's Avatar
A_J
I just got my Stang, but if I recall correctly, aren't there some hall sensors that go against some of the pulleys? That'd be another thing to check..
Old Jul 3, 2007 | 07:36 PM
Red_Stallion's Avatar
Red_Stallion
My UDP's were a snap to install and had no need for a retune or anything. I would suspect maybe you nudged one of the COP's when performing the install?
Old Jul 4, 2007 | 07:31 PM
allfyre's Avatar
allfyre
The COP's?
Old Jul 4, 2007 | 08:58 PM
modular81's Avatar
modular81
When i had my 2004 gti installed the steedaudp's but overtorqued the crankbolt because i didn't realize my torque wrench didn't work. Several days later i started getting random misfire codes. I called steeda's tech line and told them my problem. They asked if i followed the torque specs exactly and i told them i possibly overtorqued the crankbolt due to a faulty torque wrench. They said to remove and reinstall the crank pulley to the torque specs. Once i did this i never got any more random misfire codes. There is a very sensitive crank trigger sensor that can cause the misfires if the crank bolt isn't torqued exactly to specs. This could be your problem or not, just though i would throw that out there for you.
