Remote Start question
Old Jul 5, 2007 | 04:21 PM
unsocbl's Avatar
unsocbl
Default RE: Remote Start question
Here's a link to one that you can install yourself:
http://www.sjgreatdeals.com/scy2000rsm.html
And here's a good site that explains why it should only be done on cars with Automatic transmissions.
http://www.carstereo.com/help/remote_start.cfm
It's illegal in a lot of states to install one into a manual, so you're probably not going to have much luck finding someone to do it.
Old Jul 5, 2007 | 05:27 PM
Orion_240's Avatar
Orion_240
can you picture it now?
Youtube video of some people exiting a shopping mall approaching the parking lot. One of then is going to start his new manual Mustang with his remote from 100 feet away. We pan from him to his car as we hear the alarm turned off, then watch as it proceeds to jump the parking curb and go into the main lane of the mall, where it is smashed into by a Coca-Cola truck!
Old Jul 5, 2007 | 07:05 PM
Alloyed's Avatar
Alloyed
I don't recommend this but the only place I can think of in the Tampa, FL area (Which i assume you're in) is Buzz Off on Dale Mabry. They do custom alarm systems, stereo systems and did my windo tinting. Try using them. Again, I don't think this is a good idea but...if you want to do it, I believe these guys could figure it out.
Old Jul 5, 2007 | 07:26 PM
Scotty07's Avatar
Scotty07
Call Compustar or Astrostart (look up their info on the www). These are two companies who make remote starts for manual trans vehicles. They can tell you who installs in your area. You can then call the installer and inquire if they will do a manual trans kit or not.
Now, for all of you The Sky is Falling types. Here is how it goes with Compustar which is what I have in my manual trans GT. There are safeguards to prevent you from starting the car when in gear. You need to arm the starter for remote start. As you arrive at you location, you push brake pedal, car in neutral, then clutch out, then e-brake on. Take key out, the car will remainrunninguntil the driver's door is shut, at which time the car turns off, then locks the doors. This tells the computer that the car cannot be in gear. If you open a door, or unlock the car, you cannot get back into the remote start program. Astrostart works similiar.
Old Jul 6, 2007 | 01:49 AM
doode's Avatar
doode
I have a compustar 9000FM 2 way.
I have a 5 speed manual.
Compustar have designed a remote start to start your car, even with a manual tranny.
Essentially, there are a bunch of steps to take when leaving your car and arming it to be able to remote start without it rolling away.
With the Mustang, you CANNOT make it work properly.
You need an immobilizer bypass for the immobilizer embedded in the key, and that immobilizer + programming additional keys + programming the alarm in a set time frame (15 seconds from compustar for leaning) doesn't work.
As a side job, the shop that installed the alarm basically tricked the alarm into thinking its an automatic. Essentially , it will crank my motor regardlesss if its in gear or not.
That means i have to be 110% positive that my car is in neutral before i hit auto start.
Hope that makes sense.
Old Jul 6, 2007 | 02:52 AM
cmj's Avatar
cmj
That's the problem. I'd never waste my money on something that relies on guesswork, especially when the safety of your car or anyone around it is involved.
Old Jul 6, 2007 | 03:47 AM
Scotty07's Avatar
Scotty07
ORIGINAL: cmj
That's the problem. I'd never waste my money on something that relies on guesswork, especially when the safety of your car or anyone around it is involved. And again, the car remains running until the driver exits the car and shuts the door, so itHAS to be in neutral,or it is driving away as you get out. The car then shuts off and arms for starting. Unlock the doors, or open the door will disable this.
In a Mustang, explain to me how you can leave the car while it is running with it in gear and not realize it as it is driving away...?? I have had it installed for 5 months, use it every day, many times a day, and not a single issue.
GimpyHSHS
Aug 29, 2015 06:30 PM
Calizic
Aug 28, 2015 01:46 PM
movielover40
Aug 27, 2015 10:13 PM
stormesixx
Aug 25, 2015 09:11 AM
