Running too Lean
Old Jul 9, 2007 | 07:23 PM
Dex's Avatar
Dex
Default Running too Lean
The tuner im working with is well...hard to get a hold of. I got the pinging fixed in the lower RPM's but now when i go 50% or more on the throttle my wideband shoots to 16AFR and jolts like hell!!! Is there anyway I can fix this by modifying the tuneor does he have to do it??? Can i add fuel??
Old Jul 9, 2007 | 07:53 PM
TrIpOd's Avatar
TrIpOd
Default RE: Running too Lean
welcome to the world of turbos. all i can say is keep fine tuning it as much as possible. it could take a while to get it perfect.
Old Jul 9, 2007 | 08:21 PM
06SaLeEn's Avatar
06SaLeEn
I ♥ Acer
What is it at WOT?
Old Jul 9, 2007 | 09:30 PM
06tyrfryr's Avatar
06tyrfryr
If you have a tuner, I have the predator and you can go into the WOT wide open throttle and add fuel at 2-4k and at 4-7 k. I would add about 10%and recheck until you start getting close. I am running about 12.8 to 13.0 and produce the most power in that range with no other problems. 16% is way too lean. good luck
Old Jul 9, 2007 | 11:39 PM
Dex's Avatar
Dex
so add 10% toward the rich side right? i cant get to WOT cuz my engine wont let me! shoots to 16!
Old Jul 10, 2007 | 06:33 AM
06SaLeEn's Avatar
06SaLeEn
I ♥ Acer
Your A/F will go all over the place, mine shoots up to 14's-15's for a split sec, you have to let it catch, the most Important thing is WOT, What Kind of A/F gauge do you have? Again mine shoots all over the place during 5-75% untill it catchs up then it reads perfect WOT. Did this just start? Go to the tuner shop but I think your fine.
Old Jul 10, 2007 | 10:14 AM
Dex's Avatar
Dex
if i gun it then my car jolts forward. plus when you press the pedal it shouldnt go lean it should go rich. I use Autometer
Old Jul 10, 2007 | 01:38 PM
06SaLeEn's Avatar
06SaLeEn
I ♥ Acer
You got more issues than being lean IMO. Go to the tune shop asap. Keep it slow of course going there.
Old Jul 10, 2007 | 01:55 PM
Dex's Avatar
Dex
well its getting better. the only tune shop for mustangs in Utah is one that has blow up 5 cars that i know of. 5!! so i wont be going there
Old Jul 10, 2007 | 01:57 PM
sccaii's Avatar
sccaii
Dex.
Only way to be 100% sure it to get the car on a wideband and see whats going on. Datalogging the timing and RPM might help. Based on what I read above sounds like your tune was done maybe when it was cooler out? If that is the case you are probably seeing a function of to much timing than total fuel. At some point more fuel at 93 octane isn't the answer the answer is less compression(either static or boost)or less timing to reduce cylinder pressure. Turning up the fuel if its not the fix could result in enough detonation to break something....pulling time will only cut power which as it stands isn't as important as longevity.
Pull some timing or put in some C16 and see what happens is my vote.
