Sponsored by:
Sponsored by:
Fuel Filler Neck
Old 01-06-2005, 01:58 PM
GT Premi
GT Premi's Avatar
Default Fuel Filler Neck
I had my first fillup the other day and had a hard time filling it. The pump kept shutting off as if the tank was topped off, even though I had only pumped maybe 3 gallons. Someone posted of the same problem on another forum. He said he tried 3 different pumps with the same result every time.
I had to pull the nozzle almost all the way out to fill it. Has anyone here experienced that with their '05 'stang?
GT Premi is offline
Old 01-06-2005, 03:23 PM
raddroxx
raddroxx's Avatar
Default RE: Fuel Filler Neck
yep, had the same problem.
raddroxx is offline
Old 01-06-2005, 03:55 PM
VaporDude
VaporDude's Avatar
Any remedy to this?
VaporDude is offline
Old 01-12-2005, 04:22 PM
96GTponyup
96GTponyup's Avatar
I think maybe the neck to the gas tank is sideways. I had the exact same problem but when I tunred the pump sidways it filled up just fine. Try that and see if it works.
96GTponyup is offline
Old 01-12-2005, 11:23 PM
Daniel60
Daniel60's Avatar
I've had that problem too but with just one gas station.
Daniel60 is offline
Old 01-16-2005, 12:45 AM
tammijoe
tammijoe's Avatar
Haven't ran across that problem yet.
tammijoe is offline
Old 01-19-2005, 06:05 PM
blue_mazi
blue_mazi's Avatar
Ford has no fix for this problem, though they recognize it and are working on it. my 05 gt was at the dealer for over a week. dealer worked with ford engineering and replaced a bunch of parts to no avail.
they sent me home with my car finally and said ford MAY have a fix in a month or two.
if you're buying, might want to ask the dealer to not cash the check until you've filled up a couple of times.
i am meeting with the selling dealer management on friday to see what they'll offer.
blue_mazi is offline
Old 01-19-2005, 07:21 PM
05GTneckbraker
05GTneckbraker's Avatar
I had the problem too, but only when the gas station has rubber around the fuel pump nozzle. All gas pumps without the nozzle cover/splash protector fill my tank up as normal...so i've just learned which station has which in my driving area and havent had any problems.
05gtneckbraker
ps be ready for your service engine soon light to come on, seems to be a wide spread problem, I'm taking mine in to the dealership in the morning, I'll post what they did to fix it asap
05GTneckbraker is offline
Old 01-20-2005, 08:14 PM
Legend Lime
Legend Lime's Avatar
I haven't had that problem at all and I've filled my tank five times since I got my 05 Legend Lime, I only use Racetrank stations and they do have the vapor recovery nozzle on their gas pumps. How many miles did you have on your 05 when the check engine soon light came on.
Legend Lime is offline
GimpyHSHS
19
12-19-2023 01:12 PM
4cylinderplus2
10-09-2020 07:45 PM
Sixx
10-05-2015 07:36 PM
svfetter
10-05-2015 11:39 AM
mrappe
09-26-2015 10:16 AM
Quick Reply: Fuel Filler Neck
