Sequential help!!!!
Old Jul 16, 2007 | 04:46 PM
Dwisforme05's Avatar
Dwisforme05
Default Sequential help!!!!
AHHHH my left side sequentials cut out today. the wierd thing is i cant tell if i just need new bulbs or what. they ALL cut out on the left side which is kinda wierd. another wierd thing is when i lock my car they light up but not when i signal to the left. if i put on my caution lights they dont work on the left side either! has anyone had this problem or know how to fix it. any info would help thanks!
Old Jul 16, 2007 | 05:06 PM
olvanish's Avatar
olvanish
Default RE: Sequential help!!!!
Check the bulbs first, make sure both fillments are good on all of them, but I don't think all 3 of them would go out at once. Check your LH turn signal fuse (fortunately I haven't had to mess with the fuses on mine yet, but I'm pretty sure it'd have 1 for left and 1 for right side). If it only has one nevermind that. I wish I could help you any further [&o]
Old Jul 16, 2007 | 05:14 PM
FlaPony's Avatar
FlaPony
Is it plug and play or a splice in kit? If it's a splice kit make sure all the connections are good
Old Jul 16, 2007 | 05:25 PM
Dwisforme05
ok well i went out and tested the brakes to see if the brighter filiment worked. they worked on 2 of the 3, ( if the left tail lights were labeled from left to right. 123 only 1and2 worked. but when i tried to signal none of them did. is 3 shorting the rest out?
Dwisforme05
its plug and play
Old Jul 16, 2007 | 08:17 PM
Dwisforme05
its fixed!
Old Jul 16, 2007 | 08:21 PM
grampa_stang's Avatar
grampa_stang
Good job on the troubleshooting. I just installed mine not 30 mins ago.
Gotta love 'em! So, what was the fix?
Old Jul 16, 2007 | 09:09 PM
gatkins94's Avatar
gatkins94
ORIGINAL: Dwisforme05
its fixed!
ummmm.....What fixed it?
Old Jul 16, 2007 | 10:02 PM
Dwisforme05
well i guess if the first one doesnt fire off, neither will the others. ive had bulbs go out and the other two have still worked so i guess the plug and plays are wired wierd. so all it was was a bulb. ha thank goodness, my worst worry was a connection. and yes grampa stang, sequentials are the ****!!!! haha
Old Jul 16, 2007 | 10:09 PM
owero01's Avatar
owero01
I just installed mine on Saturday evening. Got to love them. Even when you hit the brake, it starts out sequential and stay solid.
