Help With TSB 06-4-1: Difficult to Do Myself?
Old Jul 20, 2007 | 08:21 AM
Vernon Tull's Avatar
Vernon Tull
Default Help With TSB 06-4-1: Difficult to Do Myself?
Several of you have discussed TSB 06-4-1 regarding the persistent rattle noise from the center stack and gearshift area of S197s. I've read the TSB and see that they prescribe worm clamps on the exhaust hanger isolators. I'm not nearly as mechanically capable as many of you gentlemen, so my question is . . . is this a difficult job or is this something a guy with basic tools and maintenence skills can handle? Thanks.
Old Jul 20, 2007 | 10:03 AM
PROMETHEUS PRIME's Avatar
PROMETHEUS PRIME
Default RE: Help With TSB 06-4-1: Difficult to Do Myself?
Very simple.
1) Jack the car up enough to were you can fit and reach the hangers.
BE SURE TO USE JACK STAND!!!!!
2) Open the clamp all the way so it's now aC shape
3) Feed the end of the clamp over the crossmember
( this will be the hardest part as to get it out the other opening thats a little tight)
4) Then just reatatch the clamp over the rubber part of the hanger.
An electric screw driver makes it alot more easier to do. I would take better pictures for you but I/m not at work. Hope tgis helps
Old Jul 20, 2007 | 11:25 AM
Vernon Tull
Thanks, PROMETHEUS PRIME, for your help. Yes, I was wondering about clearance. Would sturdy ramps work instead of jackstands? I have the 7 or 8 inch ramps and I didn't know if that would give me enough work room or if I would need to finda garagewith a lift to help me out.
Old Jul 20, 2007 | 11:28 AM
PROMETHEUS PRIME
A lift is always the best. But as long as you can fit under the car safely you should be fine. If you use ramps be sure to chalk the tires.
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
UrS4
Sep 30, 2015 10:13 AM
04stangman
Sep 26, 2015 09:33 AM
ASF88
Sep 3, 2015 06:53 AM
