yet another hood pins thread
Old Jul 20, 2007 | 07:09 PM
lldsandsll's Avatar
lldsandsll
Default yet another hood pins thread
just got a set cuz im tired of hood rattle. got 'em from pep boys, 12.99 for the pin set (all stainless steel), and 4.99 for the lanyards (plastic coated). so experts, here are my questions:
1) i found a spot a bit up and to the right of the outter rubber stoppers the hood rests onthat you can just screw the pins i got into without drilling, i still intend to use the nuts, but what does everyone think of this location?
2) after you drill thru your hood, do you have to do anything to treat the metal around the holes so that they don't rust, or the paint doesn't peel away, etc?
thanks!!!!!
Old Jul 20, 2007 | 07:19 PM
Gunrnr's Avatar
Gunrnr
Default RE: yet another hood pins thread
Why is your hood rattling? I think you can adjust the rests (rubber stoppers) if that would keep you from drilling into the hood. I am not a fan of hood pins, but if you are to install these, at least they would be operational, not "paste on's". Good luck!
Old Jul 20, 2007 | 07:23 PM
lldsandsll's Avatar
lldsandsll
no, mine are functional, not paste on. my hood lifts when i hit high speeds. i noticed it around 120, 130. i thought it was going to come off.
Old Jul 20, 2007 | 08:00 PM
RodeoFlyer's Avatar
RodeoFlyer
Hood shake on these cars is unnerving. Try it on a banked oval at 145
Old Jul 20, 2007 | 08:10 PM
lldsandsll's Avatar
lldsandsll
ORIGINAL: RodeoFlyer
lmao! i know, i thought the hood was gonna fly off and i was gonna kill everyone on I-95. i've taken the car 145+ and never noticed before, but when i finally did notice it, time for pins!
Old Jul 20, 2007 | 08:51 PM
PROMETHEUS PRIME's Avatar
PROMETHEUS PRIME
You should coat any metal showing. Have you tried adjusting the stops. Might want to try it before you drill your hood unless you really want the pins.
Old Jul 20, 2007 | 09:33 PM
lldsandsll's Avatar
lldsandsll
ya i tried the stops, didnt help. im glad i can put in pins anyway! so osh, what should i coat the metal with? i was thinking of hitting it with a bit of primer, and then some touch up paint. what do u think?
thanks
Old Jul 20, 2007 | 09:46 PM
2k05gt's Avatar
2k05gt
The hoods are Aluminum so they won't rust, paint the hole you drill under the hood
BOB ROME
Jul 26, 2023 01:54 PM
PaulH2
20
Jan 31, 2016 09:48 AM
Dokilar
15
Oct 16, 2015 08:13 PM
Urambo Tauro
Oct 5, 2015 09:37 PM
KingRando
Oct 2, 2015 08:06 AM
