dash board
ORIGINAL: The Deej
I'd start with the fuses, check em, see if it's popped. Replace it with a new one and see if it does it again. If it does you got yourself a short somewhere.
+1. Most definantly a fuse. Check both the panel fuse box and the one under the hood.
ORIGINAL: ohsixgt1217
ORIGINAL: The Deej
where can I find the panel fuse??
never had this happen before??
noo I dont I just connected my sct II controller and everything just died??
I really dont know what to do I dont know how much gas or anything because the whole dash board wont work?? anyone please helpp..
ORIGINAL: DarkFireGT
You wouldn't happen to have an iPod adapter wired in, would you? I've heard of some of those causing similar problems.
Some how you toasted a fuse, the panel is in the passenger footwell on the outside. There is a small rectangular panel pop it offm and lift the white flap and the fuses are behind. The schematic is on the back of the panel, you can get more fuses at any parts store, or even wal-mart. Use the SAME size fuse.
Good Luck!
Good Luck!
