Rear Supsension Squeak...
Old Jul 21, 2007 | 11:30 PM
seniorsmith's Avatar
seniorsmith
Default Rear Supsension Squeak...
My car has this very annoying squeak somewhere in the rear suspension [:@]... I notice it more when it is cooler and damp out. It seems to be coming from the passenger side rear. Anyone else have/had this problem? Help me get rid of it PLEASE.
Old Jul 21, 2007 | 11:40 PM
owero01's Avatar
owero01
Default RE: Rear Supsension Squeak...
Does it happen when you do a turn? If so, there is a TSB about moan from the rearend.
Old Jul 22, 2007 | 02:41 AM
seniorsmith
ORIGINAL: owero01
It does it no matter what. If it is a REAL smooth surface, it doesn't seem to do it. I thought it had to do with the rim as it sometimes is in tune with how fast I'm driving.
EXAMPLE:
If I drive slow - squeek.....squeek......squeek[:@]
If Idrive fast - squeek,squeek,squeek,squeek [sm=smiley35.gif]
Again, I thought it was my rim but It doesn't do it all the time.One day it was doing it so,I put my spare on and it stillDID it. [sm=headbang.gif]
Old Jul 22, 2007 | 02:45 PM
FyouGitive's Avatar
FyouGitive
It's difficult to determine the true location of a squeak source. Sound may be conducted aling various componnts to a place where it can escape to vibrate some air. Get someone to drive you around while you move from place to place in the car. A stethescope would help.
My first impulse would be to spray a little Armorall or Silicon lubricant on the places where rubber meets metal: exhaust hangers, then if that doesn't do it, sway bar bushings, and maybe spring seats.
I had a persistent squeak in the rear of my car, isolated to one side. When I changed rear sway bars from a painted one to a powder-coated one, the squeak was gone. Paint had worn off one end of the squeakie bar, and that was the quiet end.
Old Jul 22, 2007 | 04:15 PM
seniorsmith
ORIGINAL: FyouGitive
Thanks,
I'll give your suggestions a try...
4cylinderplus2
Oct 9, 2020 07:45 PM
baddog671
Jul 26, 2016 01:20 PM
flash_xx
Oct 16, 2015 07:23 AM
UrS4
Sep 30, 2015 10:13 AM
lincolnshibuya
Sep 24, 2015 10:46 PM
