Please help ID this part
Old Jul 29, 2007 | 04:04 PM
MartyMoose's Avatar
MartyMoose
Default Please help ID this part
Well, was looking under the hood and found this dangling.
It has two numbers written on it: 5w7t-18801-aa and pbt-gf30
It has a single lead that gets buried back into a wiring harness.
I googled both numbers and the first one didn't return anything but found various threads with the pbt-gf30 number thattalk variously about the 90mm Lightning MAF, which I have.
It looks like the metal tab is supposed to be connected to something??
TIA!!
[IMG]local://upfiles/61548/271CF3695E6A49F8AAB541B91C59738B.jpg[/IMG]
Old Jul 29, 2007 | 04:18 PM
07GT4.6's Avatar
07GT4.6
Default RE: Please help ID this part
I looked in mine it goes on the rt side of the timing cover were theres a stud see if this picture helps that does not come out on its own is on there pretty tight did someone do any work on your engine???????.
[IMG]local://upfiles/75048/7AF2D717DDC0476D9565075BAF391B23.jpg[/IMG]
Old Jul 29, 2007 | 04:26 PM
doctorstrobe's Avatar
doctorstrobe
There's another one on the passemger side.
They are resistors. Not sure what there purpose is but I had to tie an intercooler water pump relay into one of them.
That metal tab needs to be bolted to ground in order for it to work. A resistor always has two connections...
Old Jul 29, 2007 | 05:57 PM
MartyMoose's Avatar
MartyMoose
ORIGINAL: 07GT4.6
Yeah, the douchbag that installed the SC! First I found they didn't clamp the radiator hose to the motor - found a stream of coolant under my car in a shopping center where luckily there was a parts shop!
Thanks guys, I'll bolt that bish back on! Appreciate the help & pic!
Old Jul 29, 2007 | 06:25 PM
drbobvs's Avatar
drbobvs
It looks like a resistor. It need to be grounded. One of its purposes is to reduce electrical noise in the audio system. There are probably other things they do too.
Old Jul 29, 2007 | 06:54 PM
sharkbait20's Avatar
sharkbait20
sure looks like a whichit clip to me...
Old Jul 29, 2007 | 07:48 PM
MartyMoose's Avatar
MartyMoose
ORIGINAL: sharkbait20
Alright, I'll bite. What's a whichit clip?
I found a place to bolt it down that's only 0.3 ohms difference from where the other one's bolted down and test drove. With that bolted back on and with the new el-cheapo (Steeda) oil separator, the car sounds growlier [8D]
Old Jul 29, 2007 | 09:44 PM
armour845's Avatar
armour845
They look like radio interference resistors, without them you could hear alternator whine in the radio. I'm not 100%, but that's what I would guess they are, either way, whatever it is, itdoesn't appear to work without a ground.
Old Jul 31, 2007 | 10:22 PM
sharkbait20
ORIGINAL: MartyMoose
a whichit is a name for something that you dont know what the real name is... which (name is) it = whichit lol sorry for the confusion
Old Jul 31, 2007 | 10:25 PM
MartyMoose's Avatar
MartyMoose
[8D]
