MOSS..black tail light bezel question
Old Aug 2, 2007 | 02:02 PM
torch red's Avatar
torch red
Default MOSS..black tail light bezel question
I put on my BSM black panel my MOSS black bezels..i scratched the bezels pretty good trying to get off the ridiculous white lettering on them..
I umderstand some of you have Spray painted then Black..Is that true..any primer needed..did u use flat or satin?
Thanks..will get pics up soon..
Old Aug 2, 2007 | 03:11 PM
157dB's Avatar
157dB
Cut & Paste Expert
Default RE: MOSS..black tail light bezel question
I ordered them also but have not received them yet.
Is the white lettering that bad to scratch it off?
Old Aug 2, 2007 | 03:58 PM
torch red's Avatar
torch red
its a pain in the Butt...just be patient..but i scratched mine a little..
Old Aug 2, 2007 | 04:32 PM
FyouGitive's Avatar
FyouGitive
Is the whie lettering paint or decal?
Old Aug 2, 2007 | 06:05 PM
underbird10's Avatar
underbird10
I took the lettering off mine with a fingernail. No scratches resulted.
I think most people who paint the bezels paint them on the inside, just to make them opaque. If you're painting the outside, make sure you prep them well first to get the paint to stick. You need to make sure and get the shine off the plastic before priming (with a plastic primer) and painting. Clearcoating is also a must since they'll get a lot of abuse from sun and dirt.
Good luck.
UB10
Old Aug 2, 2007 | 06:10 PM
Dwisforme05's Avatar
Dwisforme05
if the bezels are already black you shouldnt need to prime. just wet sand it, and scuff it up. paint it, clearcoat if u want the glossy look and PRESTO!
Old Aug 2, 2007 | 07:49 PM
NJBLK07GT's Avatar
NJBLK07GT
Have them on my stang. Just take your time with a fingernail and they will come off. Painted my with "Trim Black" spray can. Picked it up at Autozone. Has a slight shine to it but not real glossy. Didn't sand them, just wiped them off with some paint thinner and shot them. Let them dry a day or so before you install them.
later,
Old Aug 4, 2007 | 12:16 PM
157dB's Avatar
157dB
Cut & Paste Expert
Hmmmmm. Mine will need to be painted?
For the $50 I paid, they will be going back to Moss
if I have to paint them before install. The description
stated that they were black and other colors were
also available. Well of course they are available
if you have to paint them. Lost again..[:@]
Old Aug 4, 2007 | 06:07 PM
tucsondivots's Avatar
tucsondivots
I just got mine from Ninosport. I used a very small dab of "goo be gone" remover and the AVS logo slid off very easily.
Old Aug 5, 2007 | 01:18 AM
Orion_240's Avatar
Orion_240
I didn't spend enough time looking over mine so I just went over the AVS with a magic marker!
Looking back I should have sanded them and painted them flat black to match the tailight panel.
[IMG]local://upfiles/15212/24DF7AFF4F2744FC8CCB1A92F8147273.jpg[/IMG]
