Manual transmission additive?
What about Amsoil for engine oil? I thought they were the best. Some racing buddies told me they would put 15K on the stuff and it would still drain clear as if it hadn't broken down.
The royal purple thing bugs me a bit, I'll have to read up. I've used redline autotranny fluid before with excellent results. I think I may even like them better than B&M syn trickshift. If the fluid was causing more friction there would be an increase in heat correct? Are these manuals cooled at all and is there a sensor for temperature? I may have to set up gauges for oil/tranny.
I have never been a fan of RP they have a great advertising campaign but i honestly do not think their product can compete with Redline's.
I am a loyal Redline user they use very high quality base stocks. I use Mobil 1 in the engine and Redline in the rest of the drivetrain. Always have always will.
Richard
Richard
ORIGINAL: s197richie
I always thought that a short-shifter was synonymous with increased shifter effort (which is why I don't like them)...isn't this true?
Tufoil is apparently everything it is made out to be. This stuff is just insane. Already ordered some
They say not to add this to your engine until it has 5-10k miles on it. Is this true? I only have 2500...
On the Red Line oil, which one should I use?? There are a bunch of different weights out there.
ORIGINAL: Valyndiir
Keep in mind Tufoil used to say don't add until 15K, so by saying 5-10K its possible theyre just trying to be 'nicer', so maybe you wouldn't want to add it even sooner than that. 5K seems ok. My opinion.
Anyways brace yourself because your engine will get annoying quiet, like after an oil change but maybe even quieter. It will get some volume again, though, but will go away again with the next use. Remember, use one full 8 ounce oil right away, with your current oil, then just replace 4 ounces with each oil change.
ORIGINAL: ohnoesaz
Also put 8 ounces in my tranny.... Didnt feel a difference but my goal is avoiding wear and tear, not to actually feel anything.
BeatnikFink
Oct 1, 2015 08:00 PM
