more power
Old Aug 5, 2007 | 10:26 AM
chuckh's Avatar
chuckh
Default more power
Ok I need more power, I have the roush 427r. If I change the pulley on the supercharger, I obviously need to change it back to stock when I go in for service, is this something I can get away with? The roush has 5psi of boost? By changing to a smaller pulley this will increase boost? Is that correct? How much can I increase and still be safe without harming anything?One more question..... is the money worth the 4:10's, or is there something else I should do first? Thanks for the help.......
Old Aug 5, 2007 | 10:31 AM
Vulcan's Avatar
Vulcan
Default RE: more power
I don't know about the pulley but the gears areworth the money.
Old Aug 5, 2007 | 11:53 AM
chuckh's Avatar
chuckh
Thanks for the input......
Old Aug 5, 2007 | 11:56 AM
cheftjpeck's Avatar
cheftjpeck
the smaller pulley will increase your boost. the gears are a great mod to wake up your car...I will not do them as in my setup it would make 1st gear non existent and traction will be tough to get on the street....good luck
Old Aug 5, 2007 | 11:59 AM
PROMETHEUS PRIME's Avatar
PROMETHEUS PRIME
Not sure about the Roush but the Saleen feels good at 10 psi. 3.4 pulley is right under 10 psi of boost.
4.10's are definitely worth it. They will increase your rpm when cruising but I feel are well worth it.
But with the increase of boost you'll need a new tune and will be a pain to swap the pulley everytime you need service.
Old Aug 5, 2007 | 02:29 PM
BigDave's Avatar
BigDave
I would be worried about tuning up the wick too much with a non-intercooled setup??
Old Aug 5, 2007 | 03:02 PM
CataclysmGT's Avatar
CataclysmGT
Roush is intercooled.
Old Aug 5, 2007 | 05:07 PM
BigDave's Avatar
BigDave
OOPS!
jrrhd73must
Oct 2, 2015 09:17 PM
KingRando
Oct 2, 2015 08:06 AM
ChampInSD
Oct 2, 2015 04:55 AM
Sep 25, 2015 06:58 PM
