shaker 500 replacement questions
Old Aug 5, 2007 | 10:09 PM
one eyed willy's Avatar
one eyed willy
Default shaker 500 replacement questions
i just got my new 07,i would like to maybe replace the shaker 500 with a kenwood navigation double den deck,what would be involved in this.i would keep all the factory speakers but possibly add a 12 to the trunk down the line.i know when there are factory amps involved things get a little compliacted so i figured i would ask about it first.
Old Aug 5, 2007 | 11:15 PM
azstanglover's Avatar
azstanglover
Default RE: shaker 500 replacement questions
You will need a wiring harness and dash kit to install the deck. You may also use a 5 volt voltage regulator to prevent the poping sound when the deck turns on. You'll probably also need to install an amplifier to power the sub. There is a recent how to on installing an amplifier. You might check it out.
Hooking it up should be pretty straight forward.
Old Aug 6, 2007 | 04:25 AM
howarmat's Avatar
howarmat
s197 Junkie
tacobill has a writeup that will help....also search for the 6 page avic z1 install thread
movielover40
Aug 27, 2015 10:13 PM
Shifty Magoo
Aug 25, 2015 03:08 PM
ccwebb
Aug 11, 2015 06:47 PM
ericunderwood
Aug 11, 2015 03:40 AM
