MyColor Color???
So, what's your fav MyColor color? Do you roll Blue? Red? Light Urple? Or your own mix?
I tend to go with the Blue.
Ps - I'm sure this should be in off topic...but only S197's have this feature...so...
Was blue for a while.. trying yellow.
ORIGINAL: 05RedHead
So, what's your fav MrColor color? Do you roll Blue? Red? Light Urple? Or your own mix?
Display Color
The instrument cluster gauges are backlit with white backlighting when the headlamps are off. When the headlamps are on, the user can select one of six preset colors or one user definable color (MyColor) for the nighttime gauge backlighting. Headlamps must be on to set up the nighttime display color.
Note: A gauge in a warning condition will be lit red when the headlamps are on.
1. Press SETUP to get to the DISPLAY COLOR set up menu.
2. Pressing RESET will scroll through the following selectable colors;
Green, Purple, Orange, MyColor,Blue,White, Red, Adjust (to define MyColor)
Adjusting MyColor is a user defined backlighting color Red, Green, and Blue LEDs. Apart from the 6 preset colors, drivers can create their own color by adjusting the levels of the three primary colors through the MyColor feature to achieve any of 125 different combinations.
The vehicle must be stationary to enter the MyColor adjust mode, To enter the MyColor adjust mode, hold RESET for 3 seconds at the Adjust menu, or press SETUP to scroll through the display colors again. When in the Mycolor adjust mode, pressing RESET will step through the Red, Green, Blue and Exit options. Pressing SETUP will increment the proportion of the color being adjusted. Try many combinations and record your favorites. To Save and Exit MyColor adjust hold RESET for 3 seconds when prompted. Pressing REST for less than 3 seconds will cycle back through the color components.
Hope this helps!
Hope this helps!
