Driveshaft clearence
So when you lower the car and you make sure you have everything aligned right like, panhard bar, lca's, etc. Is this still a problem?? Im going to need a new drive shaft after i twist mine off but i just put lowering springs on. (pro kit)
Shouldn't be a problem. I have the Eibach kit and no problem with speed bumps. You will have to watch out for driveways that go up and then there is a drop. It it looks steep, don't go.
Boostaddict
2.3L Eco-Boost Tech
Nov 24, 2015 06:11 AM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
