Having problem with Diablosport B@ma tune install.
Old Aug 7, 2007 | 07:17 PM
armour845's Avatar
armour845
Default Having problem with Diablosport B@ma tune install.
I received my Diablosport with all three Bama 93 tunes, when I try to install the tune, I click on performance tune, and I get unable to find vehicle type error, anyone know what the problem is.
I already tried to contact Doug but it is after business hours.[/align]
Old Aug 7, 2007 | 07:21 PM
owero01's Avatar
owero01
Default RE: Having problem with Diablosport **** tune install.
Did you give him the right code for your car? That can cause a problem with the install.
Old Aug 7, 2007 | 07:24 PM
armour845's Avatar
armour845
The code on the PCM and on the order from B@ma is XZE2. So hopefully that is right.
Old Aug 7, 2007 | 08:36 PM
armour845's Avatar
armour845
^^Bump^^
Old Aug 7, 2007 | 08:38 PM
aschultz91's Avatar
aschultz91
Has the dealership ever flashed your computer? If they have im pretty sure it changes the pcm code and that can cause tune problems i think
Old Aug 7, 2007 | 08:49 PM
armour845's Avatar
armour845
ORIGINAL: aschultz91
The car has not been back to the dealer since the day I bought it. I'm thinking the tuner has the wrong cal code installed but wanted to see if it is something else. I double checked the PCM code and the code I sent Doug. They are both the same. Soooo! I've already took the JLT back off the car. I'll be sure to install the tune first next time, even though it was a snap to install and remove, it sucked to undo things.
Old Aug 7, 2007 | 09:03 PM
howarmat's Avatar
howarmat
s197 Junkie
The diablo doesnt need the PCM like the SCT does. Never seen that happen before. Ahh!!!!
The 07 has a different diablo than the 05-06 model.....what is the model of the diablo you have?
Old Aug 7, 2007 | 09:13 PM
armour845's Avatar
armour845
ORIGINAL: howarmat
During the boot up the part number says U7145, which I verified via Diablosports website as accurate for the 07 GT. The good news is my car still starts, the bad news is I had to remove the JLT
Old Aug 7, 2007 | 09:36 PM
howarmat's Avatar
howarmat
s197 Junkie
Plud the tuner in and then read the strategy code for us....
Old Aug 8, 2007 | 04:41 PM
armour845's Avatar
armour845
I'm assuming this is the cal id number, when I tried to access it, I got the same error message( unable to find vehicle information), I also checked the revision number on the Predator and it is the current version (v.8r06) I've tried to call and email Doug and no reply, as usual. Good thing I can still drive my car!
Also the serial number is d00c4d7
part # is u7145
