auto burnout
Old Aug 10, 2007 | 12:20 AM
dirtriderdrew77's Avatar
dirtriderdrew77
Default auto burnout
anyone know any tricks or tips to get the rear wheels spinning on my 6er. its an 05 there is no tcs or anything fancy like that. in the rain it is very very easy to spin but dry is impossible. thanks
Old Aug 10, 2007 | 12:22 AM
oshkoshbajawsh's Avatar
oshkoshbajawsh
I ♥ Acer
Default RE: auto burnout
turn overdrive off and get a tuner/cai
Old Aug 10, 2007 | 12:29 AM
ucdgreek's Avatar
ucdgreek
^^what does overdrive have to do with it. thats 5th gear
Old Aug 10, 2007 | 01:19 AM
Burnsy's Avatar
Burnsy
may not be so great for the tranny, but if all u wanna do is spin the wheels, find a slight incline, let ur self roll down it slowly in neutral, hit the gas, and flip it into [D], should do the trick
otherwise, powerbrake, idk, mOd it some,
Old Aug 10, 2007 | 02:27 AM
mygt500's Avatar
mygt500
Multi-Tasking Moderator!
just like he said above do a neutral slam amd have fun.....it will wear on the tranny in the long or short run. It is hard on the motor mounts as well.
Old Aug 10, 2007 | 07:21 AM
MrSandman's Avatar
MrSandman
You should have no problems doing a burn out. Just have one foot on the break and give it a little gas... then let off the break. First time I did this I just kept the gas down halfway and smoked the hell out of my tire for about 30 feet.
Remember though.. one tire burn outs aren't cool... Just look at what I wrote above "I smoked my tire ..."
Old Aug 10, 2007 | 08:12 AM
Va. Stang's Avatar
Va. Stang
Go find two cylinders and install them. J/K... Do the brake /gas thing! That should get them going. If not find a wet spot.lol
Old Aug 10, 2007 | 08:31 AM
odiaz's Avatar
odiaz
get a line lock kit. It will apply the brakes on the front wheels only as long as the button is pressed, the rear wheels will spin. When you release the button, the car will shoot off like a rocket.
Old Aug 10, 2007 | 08:53 AM
Dwisforme05's Avatar
Dwisforme05
ORIGINAL: oshkoshbajawsh
um....no.
ok here is what works the best for me. pump the break a little bit as if u were trying to launch it, then rev it up to about 1200 with your foot still on the break. then quickly let the break go and then press it back on. the car will jump forward a little bit but then the rear tire(s) will break loose. it works. for me i can just hold the break and press the gas then once it gets to 2k the wheel breaks loose. so work with it, just dont rev it past 2k. its not good for the car. burning out period isnt good for it, but its fun!
Old Aug 10, 2007 | 08:55 AM
badtzmaru's Avatar
badtzmaru
why waste your tire, save it for a rainy day.
