royal purple question
Old Aug 10, 2007 | 01:42 PM
brendend's Avatar
brendend
Default royal purple question
i just switched over to royal purple and was wondering how often you should change it. 3k like normal oil or 5k like syntetics? thanks
Old Aug 10, 2007 | 01:52 PM
BuddaBing's Avatar
BuddaBing
Default RE: royal purple question
i'd say 5000 unless you dog your car.have you noticed any differance?
Old Aug 10, 2007 | 01:54 PM
brendend's Avatar
brendend
actually i noticed a little difference.
Old Aug 10, 2007 | 01:56 PM
howarmat's Avatar
howarmat
s197 Junkie
5k or 4-6 months depending on how you drive. When i put RP i did notice it was alot smoother
Old Aug 10, 2007 | 01:58 PM
Va. Stang's Avatar
Va. Stang
4to 5 thousand should be ok. But beware, synthetic oil will get very very thin when used. I have seen it blow by the rear main when run hard. Yes, it was due for an oil change. Had 4 thousand mileson the oil.
Old Aug 10, 2007 | 02:03 PM
BuddaBing's Avatar
BuddaBing
i have been thinking about going the whole route, RP rear end ,auto trans and motor. im in texas and its HOT!
[IMG]local://upfiles/65830/CDF3D22C48504275B9682CC3C5C0D0EF.jpg[/IMG]
Old Aug 10, 2007 | 02:08 PM
RICAKILLA's Avatar
RICAKILLA
It has Moly in it.. thats not good for oil lines...
Old Aug 10, 2007 | 03:03 PM
torch red's Avatar
torch red
I got RP in all 3 inputs ..[>:]
Rear Diff...Tranny..Oil...i am happy with it..
Old Aug 10, 2007 | 04:03 PM
androdz's Avatar
androdz
I ♥ Acer
ORIGINAL: brendend
Dont even run 1 mile with that Royal Crap -.-. It does not meet the latest Oil Standards... Go with Redline 5w-20 hands down the best 5w-20 out there. If not then Just get mobile 1 full syn.
Andrew
Old Aug 10, 2007 | 04:08 PM
GidyupGo's Avatar
GidyupGo
I once switched to RP and it was vaporizing or getting past seals. The oil level would drop 1 qt in 3000 miles. Switched back to conventional oil and the used stopped. Didn't leak a drop or us any since. This was in my 1997 F 150. So, if you use it, keep an eye on the oil level.
