shifter knob
Old Aug 11, 2007 | 02:01 PM
jerrym's Avatar
jerrym
Default shifter ****
How does the stock shifter **** come off. Can it be replaced with the Hurst styled ball. Just wondered for appearance sake until I can order the real thing.
Old Aug 11, 2007 | 02:08 PM
sactown's Avatar
sactown
Default RE: shifter ****
it should just twist off, just an fyi I just had a hurst short throw shifter installed and at this point I am not crazy about it. Its a little noisy when you shift not gears grinding but just not smooth. I may go back to stock or the Pro 5.0.
Old Aug 11, 2007 | 02:17 PM
jerrym's Avatar
jerrym
Thanks for the info, was really considering whether to change out shifters or not, heard anything about the MGW shifter?
Old Aug 11, 2007 | 03:01 PM
sactown's Avatar
sactown
No I have not heard anything about that shifter.
Old Aug 11, 2007 | 05:10 PM
07 Mustang GT/CS's Avatar
07 Mustang GT/CS
I have Hurst shifter & love it.Throws are short & smooth shifting..Def worth the money for sure..My shifter does not grind,vibrate, rattle,etc..Love the way it looks too...
Old Aug 11, 2007 | 07:18 PM
FlaPony's Avatar
FlaPony
The MGW shifter is awesome, just ask around...also the customer service they provide is second to none
Old Aug 11, 2007 | 07:33 PM
kenthicken's Avatar
kenthicken
Pretty easy to do: the boot has a rubber grommet thing on the end that attaches the boot to a groove in the bottom of the shifter ****. It's flexible, so you can gently "roll" it off the bottom of the shifter ****. After it comes loose, you can unscrew the ****. The shifter does not bother me, but I hated the **** from the factory, so I bought a white Roush shifter ball for $30, and put it on. Goes on with no problem... and it's a lot less than a complete Hurst shifter.
carid
Jul 8, 2016 09:55 AM
firehorse02
Nov 16, 2015 11:28 AM
Explosive
Oct 2, 2015 07:45 AM
guitarman376
Sep 30, 2015 05:54 PM
junior04
Sep 28, 2015 10:53 AM
