Wheels? Good or Bad?
Old Aug 16, 2007 | 12:26 AM
white07's Avatar
white07
Default Wheels? Good or Bad?
Okay guys I pretty set on the style of wheels I want which are Saleen wheels.
My question is would running 17x9s up front and 18x10s out back look okay?
http://www.americanmuscle.com/17x9-s...rome-2005.html
http://www.americanmuscle.com/18x10-...05-chrome.html
Old Aug 16, 2007 | 12:15 PM
Pantera72's Avatar
Pantera72
Default RE: Wheels? Good or Bad?
ORIGINAL: white07
It will look fine as long as you get tires with either an equal aspect ration, or an aspect ration that is that is a greater height in the rear. Aspect ration is the amount of rubber between the rim and the ground (outside of the tire). Having a tire with a noticeably smaller aspect ration in the rear would look kinda retarded, because your car would looked like it was jacked up in the wrong direction.
Old Aug 16, 2007 | 12:32 PM
Tracedaddy's Avatar
Tracedaddy
ORIGINAL: white07
Why would you do that?
Old Aug 16, 2007 | 02:42 PM
white07's Avatar
white07
ORIGINAL: Tracedaddy
ORIGINAL: white07
Well ive seen this setup on a 03 cobra and the thing had a nasty stance(looked badass).
Old Aug 16, 2007 | 02:43 PM
white07's Avatar
white07
ORIGINAL: white07
And ive yet to see 17x10 Saleen S rims for the 05+ models
s2k's Avatar
s2k
There is a member on the forums that has a torch red stang and has 17's up front 18's out back and it looks sweet.
Old Aug 16, 2007 | 02:45 PM
Tracedaddy's Avatar
Tracedaddy
Hmmm. Interesting. I guess I'd like to see it too then. I'm not getting a good visual.
Old Aug 16, 2007 | 02:46 PM
Margarita Girl's Avatar
Margarita Girl
Is the tide gonna reach my chair?
I'd go with a bigger tire in the back, but not bigger rims.
Old Aug 16, 2007 | 03:11 PM
CataclysmGT's Avatar
CataclysmGT
ORIGINAL: Pantera72
ORIGINAL: white07
Aspect RATIO. Example: 275/35/18 would mean that the sidewall height is 35% of the width of the tire.
Therefore, to have the same sidewall height, you can have a wider tire in the back, with a lower aspect RATIO.
Old Aug 17, 2007 | 12:33 AM
white07's Avatar
white07
so would
275/40/17 - front
305/35/18 - back look okay?
