Installing Meter4it Seq lights..Any advice?
Old Aug 16, 2007 | 06:58 AM
theresa's Avatar
theresa
Default Installing Meter4it Seq lights..Any advice?
Any tricks....tips anyone can offer?
Hubby is getting everything ready to do the job !!
Thanks, Theresa
[IMG]local://upfiles/68400/91C6E775502C416B9A3DF86AC7B8B8A2.jpg[/IMG]
Old Aug 16, 2007 | 07:04 AM
Boozshey's Avatar
Boozshey
Default RE: Installing Meter4it Seq lights..Any advice?
Nope, it's pretty straight forward and came with everything needed. Just get it done!!! hehe
Margarita Girl's Avatar
Margarita Girl
Is the tide gonna reach my chair?
Hi Theresa,
I installed the WebElectric plug-ins. Hardest thing is getting your hands behind the plastic shroud. Remove the bolts but it will still be an abstruction to your view. Found that if you use a rag to jam the trunk flange open, it will help save your manicure! I ended up breaking one of the push clips but just spent $2 at Pepboys to replace so if you need to sacrafice one or two, not a big deal.
Old Aug 16, 2007 | 07:19 AM
theresa's Avatar
theresa
ORIGINAL: Margarita Girl
Hi Theresa,
Push clips...Is that the little black x-mas tree (that's what the dealer guy called them!!)
little screw...plug things ?? I had one replaced on the backseat carpet area.
I have something like that missing from the bottom of the front spoiler. Can I get one of those plugs fromthe auto parts store?
Old Aug 16, 2007 | 07:25 AM
Margarita Girl
Yup, good description. Bring the broken one with you.
Old Aug 16, 2007 | 07:34 AM
theresa's Avatar
theresa
It's gone...
I parked a over a parking block and it didn't scrape until we got back in and backed up. I would guess that's how it got messed up. So the black plastic piece hangs a little and I noticed one of the plugs was missing.
Old Aug 16, 2007 | 07:38 AM
28HopUp's Avatar
28HopUp
MF Administrator
ORIGINAL: theresa
Thanks, Theresa
When removing the plastic 2-piece clips that hold the plastic trunk surround in place, only pop out the center part. Once that is out, then the rest of the clip will come out easily. If you try to pop them both out at the same time, you'll need to buy new clips.
Good luck on the install. The hardest part for me was getting the hot wire through the wirewall, but I think they may now suggest a rear location for power.
Old Aug 16, 2007 | 07:58 AM
theresa's Avatar
theresa
Just took a look at it. The 2 center one's are x-mas tree plugs and the 2 a little higher
are the unscrew kind.
Old Aug 16, 2007 | 10:07 AM
Boozshey's Avatar
Boozshey
ORIGINAL: 28HopUp
No problem with the kit you plug it into the passenger side fuse box.
Old Aug 16, 2007 | 10:56 AM
theresa's Avatar
theresa
Got the lightsout and in, all done in the trunk area, took a break to feed the kids.
Now to run the wires....
Don't care for how they word the instructions, I think I could of wrote them a little clearer.
