Pony center cap
Hi ,
I want to remove the center caps from my magsthat say fordand replace them with the new pony ones I just picked up, I would like to know if I have to remove my wheels to pop off the original ones or is there a way to take them off without removing the wheels.
05vert
Thanks
[IMG]local://upfiles/68064/6BF419D9AF6441DEBD49F865FC8DECC7.jpg[/IMG]
05vert
Thanks
well if you want to keep the ford ones, probably not. if you dont care about them, you could probably break them, they are just plastic. just be careful not to mess up your wheels! haha.
sorry I didn't catch this earlier.
You can just loosen them with a thin screw driver or metal spatula.
Did you get the Pony caps or spinners?
[IMG]local://upfiles/15212/AC7972D1A93146069D5ED1958C5D349F.jpg[/IMG]
I got mine for 35 bucks from a member here and once youy loosen it with a thin screw driver it pops out and pop the new one in. ONly do the screwdriver if you dont mind some minor scuffs because i did scuff around the cap area but it not too bad.
ORIGINAL: Orion_240
I got the caps.
