push button start install
Old Aug 19, 2007 | 02:35 PM
digitalmixx187's Avatar
digitalmixx187
Default push button start install
When a push button start is installed in the s197's, can you still start it with the key or is the key only used to unlock the steering wheel?
Old Aug 19, 2007 | 02:48 PM
marcuskeeler's Avatar
marcuskeeler
Default RE: push button start install
Depends how you wire it.
You'll have to use the key tooperate the ignition circuits, but if you wanted, you could disable the key from activating the starter motor.
It's easier to let the key wiring alone and merely have the button activate the starter as well as opposed to instead of.
Boozshey's Avatar
Boozshey
Yes you can still start with the key...
Old Aug 19, 2007 | 02:49 PM
PROMETHEUS PRIME's Avatar
PROMETHEUS PRIME
I'm looking into it, but as long as the wires are spliced and not cut. The key should still start normally also.
Old Aug 19, 2007 | 02:53 PM
digitalmixx187
does anybody have an install guide for the oush button start?
Old Aug 19, 2007 | 02:58 PM
marcuskeeler
There's an echo in here
MexGT's Avatar
MexGT
ORIGINAL: digitalmixx187
http://www.cherod.com/mustang/HowTo/Start%20Button3.pdf
Old Aug 19, 2007 | 03:12 PM
Boozshey's Avatar
Boozshey
ECHO.... There is a guide at
haha
Old Aug 19, 2007 | 03:20 PM
marcuskeeler
LOL
Old Aug 19, 2007 | 04:08 PM
eric6913's Avatar
eric6913
i have mine wired to only start with pushing the button.
