Heat
You don't feel it at all? The floorboard/firewall and hump below the shifter area throw heat if I've been going for awhile. Christ, if I open the hood after driving for 30 minutes, the shock towers are too hot to touch.
Well, opening the hood and touching the strut towers is another thing
Let's not forget that the motor has two exhaust manifolds which run out past the inner fenders and under the firewall, transfered heat is an inevitable result.
But anyway, no, I can't say I've ever really noticed excessive firewall/bulkhad heat. Just the Shifter rod.
Let's not forget that the motor has two exhaust manifolds which run out past the inner fenders and under the firewall, transfered heat is an inevitable result. But anyway, no, I can't say I've ever really noticed excessive firewall/bulkhad heat. Just the Shifter rod.
How long are you guys driving for 1-2 hours ?? or more?
I guess I was driving the car pretty much all day over the Woodward cruise and I only noticed the shifter rod getting to the same temp as driving it for 30 mins in Hot traffic. It seems to plateau out.
Perhaps the guys with footwell heat issues have missing or damaged exhaust heatshields ?
