Has anyone using Nitrous had problems
Old Aug 23, 2007 | 05:27 PM
Va. Stang's Avatar
Va. Stang
Default Has anyone using Nitrous had problems
With Burning (melting down)your spark plugs. I waspricing out a complete Zex kit and was told that sooner or latter plugs would fail. That our motors run very hot at the plug.And I should be prepared for if/when it happens to spend $100 on new plugs.The $100 is no big deal. But being left stranded somewhere is. Plus any possible motor damage. Anyone?
Old Aug 23, 2007 | 05:37 PM
explict's Avatar
explict
Default RE: Has anyone using Nitrous had problems
From what I know, buy the $100 Ht0 plugs when you get the kit and you wont have that problem. correct me if I am wrong someone.
Old Aug 23, 2007 | 05:53 PM
Thurman's Avatar
Thurman
It actually depends on the shot. If you are running 75 or 100 no problem. If 125 `50 175, be prepaired to go through some plugs. Keep an extra set on you, they are easy to replace.
Old Aug 23, 2007 | 06:06 PM
Va. Stang's Avatar
Va. Stang
Thanks...I am looking at running a 100 shot. I looked at your sig, and am looking at doing close to what you have done to the motor. ie. cams ...TB and such... What kinda of times are you running.
Old Aug 23, 2007 | 06:22 PM
Thurman's Avatar
Thurman
Good luck va stang!
Old Aug 23, 2007 | 06:24 PM
06elnr's Avatar
06elnr
I am just running a 100 shot Zex and I have had no troubles what so ever, I love the juice!
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
