Not happy....
My driver seat is not working. wont move forward, back, up, down, and lumbar support stoped working. I checked the fuse and its ok. Does anyone have any other ideas before i break down and take it to the dealer???
ORIGINAL: mightymouse
ORIGINAL: wingman75
You have a warranty so take it to the dealer and tell them not to hurt your baby.
I most likly will take it in but i just wanted to check and see if any one had any ideas as to what may be going on. I wont be able to get a loaner car from the dealer because they dont give them out. Sucks but i guess i'll have to find a way to and from work for a few days....[:@]
ORIGINAL: Thurman
Their is a connector under the seat that can come disconnected. Secure it, and should be fine
I'll check in to that as soon as it stops raining here.
Thanks for the input.
The fuse is F14 in the Bussed Electrical under the hood.
The ground for the seats is behind the drivers side kick
panel. This grounds many other things so I dont think this
is the cause. You should have 12V on the DarkGreen
wire on the power seat switch. Its a simple system with
5 motors and if nothing works, its the fuse, bad wire or
disconnected plug at the switch.
ORIGINAL: 157db
