hot air
earlier today i read a post about some idiot talking about how a/c affects your time at the track... but what about turning your fan on and blowing the hot air out of the engine... does this affect performance at all by taking some of the hot air out of the engine bay...
I'm not really a good enough driver to take my car to the track, but you never noticed that your car is slower with the A/C on?
It was most prevalent with my 4 cyl cars, less with my 6 cyl (but still very noticeable), and not that noticeable (but still faintly present) in my GT.
I have a 98 Dodge Caravan (Work Truck) that I have to turn off the AC just to make it up hills around town at a decent speed so not to **** off the cars behind me in the Mile High City. Yeah, AC cause parasitic drag on the crank and lower the available horsepower to the rear wheels.
Air conditioning uses horsepower because the compressor gets it's power from the fan belt, or serpentine belt, or whatever you want to call it. The belt is driven by the crankshaft, the same thing that powers the whells through the drivetrain. So you're taking power away from the wheels. And it makes a difference at the track because of it. The heater probably does affect the time as well, but much less than the A/C does, because the only thing the heater needs is a fan to blow the air through the heat exhchanger. The fan gets it's power from the electrical system, which gets its' power from the alternator and the battery. I'd speculate that the air conditioner would add maybe 1/10th of a second to your ET (.10) . The heater would add maybe .02.
yes they do. and most of you guys talked about a/c and i asked about the fans blowing the hot air. toad touched on this im not sure if the power it takes to blow the hot air out is worth it to get the hot air out of the engine bay... i would think with the fan just on 1 it barely takes any power to blow the air which to me seems like a lot of hot air coming off the engine. i would tihnk it would it down and let the engine breathe
ORIGINAL: nkx1
