Check Engine Light
Old Aug 27, 2007 | 09:34 AM
cryptic26djp's Avatar
cryptic26djp
Default Check Engine Light
Okay so here is the deal. I am getting a check engine light and periodically a check gas cap light. I connected my xCal2 to determine the codes. However, it continuously states something about unable to find the code or code errors. Anyone have an idea?
Old Aug 27, 2007 | 10:24 AM
A_J's Avatar
A_J
Default RE: Check Engine Light
First thing I'd do is swing by Autozone and have them try thier codereader to rule out if it's the Xcal2 having issues
Old Aug 27, 2007 | 10:36 AM
hammeron's Avatar
hammeron
+1 ^^^^^
hey cryptic, has the car been running perfectly since
the dyno tune and has this CEL issue just come up
recently?
you could always try the FRPP tune (temporarily if need
be), as a last resort to see if the CEL is tune related.
Old Aug 27, 2007 | 11:07 PM
cryptic26djp
I will try the autozone thing tomorrow.
Hammeron, the car was not running perfectly after the tune. But I do not think it had much to do with the tune........
Old Aug 28, 2007 | 12:18 AM
hammeron's Avatar
hammeron
ok.....it could be that your gas filler cap has
a problem. it's possible that it's not sealing well
and this could account for the occasional gas
cap indication. this cap situation isprobably
responsible, for theservice engine soon light coming
on as well......
if i were a bettin' man, id say your whole problem is
with the gas cap.
good luck and let us know how this turns out
Old Aug 28, 2007 | 12:33 AM
Ford_Dude's Avatar
Ford_Dude
I don't know if they have this in your area but the inspection places here have a gas cap tester so if they have that in your area you could get the cap tested
Old Aug 28, 2007 | 09:31 AM
cryptic26djp
thanks for the ideas guys! i will try these and get back to you with results. THANKS!!
Old Aug 28, 2007 | 10:54 PM
cryptic26djp
no codes from the auto shop tester....gas cap didnt fix it....still F'N clueless as to what the hell is wrong here.
Old Aug 29, 2007 | 09:28 AM
A_J's Avatar
A_J
So nothing from another tester either..hmm. Well, again, if it were me, I'd next try unplugging the battery for a while to reset, and/or maybe reload the tune. Then see if it still happens.
djbigskrilla
Sep 20, 2022 01:04 AM
labudski
Aug 24, 2015 07:23 AM
microgt
Aug 20, 2015 07:12 AM
mweiland
Aug 13, 2015 05:11 PM
drumhedd2005
Aug 13, 2015 09:59 AM
