Navigation lockout
Old Aug 31, 2007 | 01:38 PM
ytix's Avatar
ytix
Default Navigation lockout
Anyone knowof ahack for the in-motion lockout feature of the factory nav unit? Or a hackallowing movie DVD's to played?
Old Aug 31, 2007 | 02:04 PM
PCstang05's Avatar
PCstang05
Default RE: Navigation lockout
Not sure if this will help or if this is what you are talking about, but I will try. My buddy has an F250 I believe and has put an aftermarket dvd player head unit into it. When he showed it to me, he said did not have it installed, he installed it himself. I believe the ground wire or something is connected to the E-brake, so that it only holds a connection when the e-brake is engaged. However, there is a specific sequence in how u put the brake on and take it off to allow the dvd player to play. If he would have had it installed, then they would have connected the wire to the brake, but since he did it himself, he did not connect that wire, and he manually connects the 2 wires in the correct sequence to turn on the dvd player while it is in gear (and with the e-brake off). You may have to do some research or ask for some other assistance for the wire location on your car and the correct sequence. Hope this information helps.
Old Aug 31, 2007 | 02:07 PM
Burnsy's Avatar
Burnsy
or a way to hook up a rear cam to it???
Old Aug 31, 2007 | 02:14 PM
PCstang05's Avatar
PCstang05
I don't know about the rear cam, can't help you out there. Sorry.
Old Aug 31, 2007 | 02:28 PM
howarmat's Avatar
howarmat
s197 Junkie
the bypass is not going to be as easy as grounding the ebrake wire......go to avic411...the factory nav is a pioneer unit.
GidyupGo's Avatar
GidyupGo
ORIGINAL: Burnsy
Ask Taco Bill. He did it.
Old Aug 31, 2007 | 02:54 PM
ytix's Avatar
ytix
Yeah, howarmat I surmised as much bout the easy grounding of thewire, no great revelation there. Been to avic411 and poked arourd there too without finding much...bout time to break out the sweet suplications to the baby Jesus.
Old Aug 31, 2007 | 02:55 PM
157dB's Avatar
157dB
Cut & Paste Expert
ORIGINAL: GidyupGo
ORIGINAL: Burnsy
Did what?
Hook a rear cam up to the OEMnav unit?
He went Alpine aftermarket, I believe.
The question was for an Ford OEM nav unit?
Its controlled by the Can Bus. Good luck
bypassing the no nav or DVD during travel.
Old Aug 31, 2007 | 03:00 PM
thxultra's Avatar
thxultra
ORIGINAL: 157db
ORIGINAL: GidyupGo
ORIGINAL: Burnsy
Did what?
Hook a rear cam up to the OEM nav unit?
He has a backup cam and over road the lock out but his is a alpine.
Old Aug 31, 2007 | 03:36 PM
GidyupGo's Avatar
GidyupGo
ORIGINAL: thxultra
ORIGINAL: 157db
ORIGINAL: GidyupGo
ORIGINAL: Burnsy
Did what?
Thanks for clearing that up. I knew he did a cam, didn't know he swopped out the unit.
