Automatic Transmission Oil Change
Has anybody had their auto trans fluid changed or changed it themselves?Who do you take it to? How long are your intervals? Hassle putting the fluid backin? This really bugs me that I can't check my trans fluid.
I have 10.5k miles and have not done it yet. I dont know but would imagine the dealer I bought it from(@8500miles) did not change it. I'm going to have to look in my haynes manual and see what it takes for that job. You can install an aftermarket pan which will give you that option as well as holding more fluid than stock but that is the only way I know of to beable to check your trans fuild.
The ones I have seen shouldnt drop below the frame rails, if your lowered ya I could see that as a possible issue but stock ride height it shouldnt be.
I would try brenspeed, give them a call they are closed today and tomorrrow I believe but should beable to answer any questions you might have.
http://www.brenspeed.com/mustang_2005/automatic.html
PMPParts has a good selection of pans to choose from.
http://www.pmpparts.com/index.php?ma...987e5cd7c37423
Call them up on Monday and Josh or Kevin will be glad to help you out!
Here is this also if you just want to make a dipstick
http://www.s 19 7 forum.com/forum/showthread.php?t=1730
