dtc code p0340 help please
Old Sep 2, 2007 | 08:39 PM
myredgt's Avatar
myredgt
Default dtc code p0340 help please
I was driving around today and the engine light came on. Not flashing, just on. I noticed nothing different in how the car drives or handles, but it still was on. I plugged in my xcal and got the code p0340. I have looked around and am not really sure what it means or how to fix it.
If anyone could tell me what it means and possible how to fix it, I would be greatly appreciative. Hopefully I won't have to make the trip to the dealer. [:'(]
Thanks.
- C
Old Sep 2, 2007 | 08:47 PM
Ford_Dude's Avatar
Ford_Dude
Default RE: dtc code p0340 help please
http://www.ford-trucks.com/tsb/fullt...php?tsb=06-2-9
Old Sep 2, 2007 | 08:53 PM
cheftjpeck's Avatar
cheftjpeck
ORIGINAL: myredgt
Thanks.
- C
cam shaft position sensor...this has been linked to the alternator having a bad diode..here is the tsb on it...all I did with mine is cleared the trouble code and it has returned once in 3 months....if you are at all nervous..bring to dealer....good luck...hope this helps
Old Sep 2, 2007 | 08:54 PM
myredgt's Avatar
myredgt
Does that mean battery or alternator?
Old Sep 2, 2007 | 08:55 PM
cheftjpeck's Avatar
cheftjpeck
ORIGINAL: myredgt
the generator is the alternator....
Old Sep 2, 2007 | 09:01 PM
cheftjpeck's Avatar
cheftjpeck
try this again since the other files are small
[IMG]local://upfiles/42783/48DC3C99C95E467F8C445B89146A4173.jpg[/IMG]
[IMG]local://upfiles/42783/9F6B5E4D525744FC863C26850A3C4902.jpg[/IMG]
[IMG]local://upfiles/42783/3EFC4182F38248E7BD3F3490F9F974B3.jpg[/IMG]
[IMG]local://upfiles/42783/68D1605F61444C21A384A2411E74783F.jpg[/IMG]
Old Sep 2, 2007 | 09:05 PM
paper doll's Avatar
paper doll
p.s. google is really helpful with codes if you next time you want a quicker answer, I found that out when the last of 4 of my o2 sensors threw a code
Old Sep 2, 2007 | 11:31 PM
myredgt's Avatar
myredgt
Thanks everyone.
Old Sep 6, 2007 | 10:47 AM
myredgt's Avatar
myredgt
**update**
I put my tune back to stock, I have a Brenspeed tune. I drove stock for a while, no code. I put the tune back in, drove about 45 min with no a/c, windows down, no code. I went inside for a while and it got hot. Went outside, started the car, no code. As soon as I turned on the a/c, theres the p0340 again. I went to advance auto, they tested the battery and the alternaor, neither which were bad.
Do you think it's the tune? Should I call Brenspeed and get a new tune?
I am goint to run my car on stock for a day or two, with and without a/c, and see what happens. If the code only comes on when the tune is in, that has to be the problem, yes? [&:]
Old Sep 6, 2007 | 05:14 PM
bl1nk's Avatar
bl1nk
I actually have a thread about this same code. I threw mine about 2 weeks ago. Sounds like exactly what happened to me...
I was also tuned by Brenspeed so I returned my car to stock along with the stock air box and drove it around for a week or so, no code. I just reloaded Brents tune yesterday and put my CAI back on and I havent thrown a code yet, so well see what happens.
Ive had his tune for close to a year now and never had any problems before now. Not sure if its related to the AC though, because I blast mine all the time since its usually in the high 90s here. Just wondering, but are you auto or manual? I would assume the tunes for each are different, so maybe it has something to do with that?
