Crack the block?
Old Sep 4, 2007 | 04:25 PM
bl1nk's Avatar
bl1nk
Default Crack the block?
Got a quick question before I possibly make a big mistake. Will it harm the engine or crack the block if I spray a little bit of water over it to cool it down a bit before I work on it, or does rapid cooling like that not effect aluminum? Thanks.
Old Sep 4, 2007 | 04:29 PM
8178A's Avatar
8178A
Default RE: Crack the block?
I wouldn’t do it! For sure you can crack the exhaust manifolds.
Old Sep 4, 2007 | 04:30 PM
Derf00's Avatar
Derf00
Gentleman's Relish
ORIGINAL: bl1nk
rapid cooling on any metal could cause warping. Good example is when you hop out of your car after driving for a while, spray the hot brake rotors with cold water. You will probably start getting a wobble when you brake. That's a warped rotor.
If you need to rapidly cool the engine, leave the hood open and point a fan at it.
Old Sep 4, 2007 | 04:32 PM
bl1nk's Avatar
bl1nk
Alright thanks guys.... Thats all I needed to know!
Guess Ill have to rig up a shop fan over the engine for a bit.
Old Sep 4, 2007 | 05:22 PM
Pwny's Avatar
Pwny
I didn't think it was that big of a deal!
Old Sep 4, 2007 | 05:31 PM
Derf00's Avatar
Derf00
Gentleman's Relish
ORIGINAL: Pwny
Working on a hot engine or just spraying it with water to cool it down? Both are whack.
Old Sep 4, 2007 | 05:35 PM
Dragon Stang's Avatar
Dragon Stang
If in doubt, read the owner's manual. Its all in there about spraying water on the engine and when, where or where not.
Old Sep 4, 2007 | 06:02 PM
bl1nk's Avatar
bl1nk
^ I was closer to my computer than my owners manual, considering that its almost 1000 miles away right now. Thanks though....
Old Sep 4, 2007 | 06:07 PM
Archion's Avatar
Archion
All Alluminum, dont do it...
Old Sep 4, 2007 | 06:37 PM
mlcrycc's Avatar
mlcrycc
Hey Bl1nk,
You aint old enough to remember the Chevy Vega, are you??????????
Mike
