ABS Braking
Hi, I am new and would like to know why most hi-end cars dont have ABS braking? Which is better, i was told that ABS helps you stop faster and I also hear it is only so that if you need to turn while braking you can.
Which is better ABS or the standard system?
Thank you
Thank you
When you say "high end" do you mean, highest $$. I ask because after a recent search for my first sports car in some time, I didn't notice any that didn't have ABS. Vette, 350Z, Infiniti, BMW SUV, etc., even the Mustang that I am glad I bought.
If you are refering to older Lambo's and such. Maybe they don't lean towards new tech., and stick with low weight, raw power, huge brakes, and prices out of most of our reach. Truefully, I haven't looked at anything that high end to see if they have ABS.
ORIGINAL: Assassins
Thank you
Thank you
Not a car expert by any means. However, I thought ABS stood for Antilock Braking System. The reason, you can still control the car is because the brakes don't lock-up. No tire skidding, thats when you can't steer with them. It was always my understanding that the ABS system gives the shortest stopping distance possible without the tire lock-up.
It would be benificial to hear more on this topic. I sure want to know if I need more experience/practice to stop in the shortest controlled distance, or if the ABS system helps me out.
You are correct that it does allow you to steer while braking. ABS DOES stop faster. rolling friction is ALWAYS greater than sliding friction. Give me a day or so and I will find a comparison of braking distances on one car with the ABS on and with it off.
Actually, ABS may cause longer stopping distances. Pure physics.....if you lock up your brakes (in a non-ABS equipped car), you are essentially "dragging" your non-turning wheels (becasue they are locked up) on the street. With ABS, the wheels keep rolling (which allows you to steer in a panic braking situation). Lots of qualifiers there (like stopping distances on gravel), but in general, your stopping distances increase using ABS brakes, but you will be able to steer yourself away from trouble, if possible with ABS.
ABS stops faster.
It allows you to hit the limit of your tires traction, without breaking it. as soon as your tire starts to skid, the system will ease up just enough to stop the skid. then clamp back down, faster than a driver can do it.
A sliding stop is your worst situation, as you have already broke traction, and are now sliding, your tires have lost their ablity to grip. Think a stop on ice... different surface, but SAME effect.
If properly driven, a driver can come very close. ABS also allows you to continue to steer.
I have read that ferrari will not put ABS on there cars because it is not "macho"
This is my understanding of it anyhow.
Marty
Marty
