code after oil change.
Old Sep 19, 2007 | 09:47 PM
allj's Avatar
allj
Default code after oil change.
The check engine light is on after I changed my oil. I have checked everythingcaps etc. I don't have a reader or a tuner at this point. Any suggestions. I am going to disconnect the battery tomorrow and see if that helps but any thoughts would be great.
Old Sep 19, 2007 | 10:03 PM
laserred02's Avatar
laserred02
Default RE: code after oil change.
take it to an autozone or similar auto parts store and they will read the code for you. Or if it is still under warranty take it to the dealer.
Old Sep 19, 2007 | 11:14 PM
alloutt's Avatar
alloutt
fo sho try the battery trick first works on almost everything for me. Autozone is a waste of time I think, the dealer only if you have to. Autozone was made to sell car soap and oil.
Old Sep 19, 2007 | 11:20 PM
Lees07GT's Avatar
Lees07GT
There is an electrical connector near the oil filter that someone on here awhile back broke or knocked loose when they were changing the filter that caused a fault. I forget what the code was, but you might try examining the area around theoil filter for a loose or broken plug.
Old Sep 20, 2007 | 12:03 AM
takotruckin's Avatar
takotruckin
i wouldnt unplug the battery. that erases the code completly, along with any freeze frame data. i'd go to autozone, have them pull the code and tell you what it is, without erasing it. then you can either fix it yourself, or go to the dealer (or another shop).
i hate working on a car where the customer clears codes themselves. you loose all data related to the code and it makes the car harder to diag.
Old Sep 20, 2007 | 01:07 AM
alloutt's Avatar
alloutt
if its a real problem wont' the code come back after the battery is connected?
Old Sep 20, 2007 | 02:23 AM
ohnoesaz's Avatar
ohnoesaz
you put the new oil in right?
Old Sep 20, 2007 | 07:22 AM
Nuke's Avatar
Nuke
[sm=funnypostabove.gif]
Old Sep 20, 2007 | 07:38 AM
GidyupGo's Avatar
GidyupGo
ORIGINAL: takotruckin
Some codes can still be stored in memory.
Old Sep 20, 2007 | 08:41 PM
allj's Avatar
allj
the code is p0172 bank 1 rich. Thoughts. I am search the forums now.
