hiccup
Old Sep 20, 2007 | 01:37 PM
buster's Avatar
buster
Default hiccup
My car has on occassion, almost stopped running for a second. Its never stalled but its like it hiccups and keeps running. It happens about once a month. Does this happen to anybody else, or know what this is?
Old Sep 20, 2007 | 01:42 PM
hammeron's Avatar
hammeron
Default RE: hiccup
check on the fuel pump TSB
hesitation after cruise
Burnsy's Avatar
Burnsy
Default RE: hiccup
5 sped? or auto?
Old Sep 20, 2007 | 01:51 PM
buster's Avatar
buster
Default RE: hiccup
ORIGINAL: Burnsy
5 sped? or auto?
5 sp
Old Sep 20, 2007 | 01:52 PM
Burnsy's Avatar
Burnsy
Default RE: hiccup
well does it happen in neutral, meaning no driver error is possible?
Old Sep 20, 2007 | 03:19 PM
FlaPony's Avatar
FlaPony
Default RE: hiccup
ORIGINAL: hammeron
+1 see if you can narrow it down to acting up after a cruise where you've maintained a pretty steady speed
Old Sep 20, 2007 | 04:35 PM
Leos06gtLL's Avatar
Leos06gtLL
Default RE: hiccup
i had a similar problem but never when stopped it was only from cruising and then accelerating heavylly it was the fuel pump ford replaced it
Old Sep 20, 2007 | 04:39 PM
157dB's Avatar
157dB
Cut & Paste Expert
Default RE: hiccup
Sneak up and scare the bee jeebies out of her.
There is possably a TSB out for your problem.
Stealership time.
Old Sep 20, 2007 | 08:47 PM
06tyrfryr's Avatar
06tyrfryr
Default RE: hiccup
mine did it on occasion after driving easy for a while and then flooring it. It no longer does it now that I have the high stall converter, but my wifes car still does.
Old Sep 21, 2007 | 02:00 AM
mygt500's Avatar
mygt500
Multi-Tasking Moderator!
Default RE: hiccup
Fuel pump TSB....sounds like it to me. Time to make a trip to Ford.
