spoiler help
Old Sep 22, 2007 | 01:27 AM
justang07's Avatar
justang07
Default spoiler help
i have a 2007 torch redgt with the stock spoiler.
i want to put the roush spolier on now will the holes that are there be covered by thenew spoiler? or will it beholes in a spot that the new 1 wont cover?? canany 1 can help me out here with some info or anything thanks guys.
Old Sep 22, 2007 | 01:28 AM
ratnacage's Avatar
ratnacage
Default RE: spoiler help
The stock holes match, but you also have to drill new holes for the two extra pieces (I had a pro do it)
Old Sep 22, 2007 | 01:33 AM
justang07's Avatar
justang07
i was going to have a body shop do it. so you are saying that it fits into the stock holes and new holes need to be added how do those 2 side pieces hold up with that sided tape is it strong or is there play
Old Sep 22, 2007 | 06:29 AM
Eleanor06's Avatar
Eleanor06
The center sections uses the stock holes,its the two side piece's that need holes drilled.Some people have used
just the 3M tape,but thats up to you.I prefer bolting them on.
Old Sep 22, 2007 | 08:15 AM
06elnr's Avatar
06elnr
I bolted mine also, it comes with some little cardboard pieces that you use as a template and it was kinda easy to do...I set mine on the car and got them where I wanted them then outlined them with blue tape so you can open the trunk so you have more room when you are drilling. It really helps if you have an extra pair of hand to help you.
Galactic
Apr 29, 2019 02:56 PM
belam
May 6, 2016 06:24 PM
Gene K
Oct 21, 2015 11:37 PM
GLOCKer
Sep 28, 2015 07:36 AM
Mr. D
Sep 17, 2015 08:17 AM
