Suspension Question
Old Sep 28, 2007 | 09:35 PM
jgallo's Avatar
jgallo
Default Suspension Question
I just purchased Ford Racing springs and shocks, when I put this on what all needs to be adjusted, or is not enough of a drop to effect anything. Any input would be great, Im having it done Monday, thanks for the help.
Old Sep 28, 2007 | 09:43 PM
Mikes_BLK_GT's Avatar
Mikes_BLK_GT
Default RE: Suspension Question
Well there is alot more to do if want to give this a read should answer many of your suspension questions andmay even create a few.
https://mustangforums.com/m_1696246/tm.htm
Old Sep 28, 2007 | 09:48 PM
Black07gt's Avatar
Black07gt
pics!!!!!!
Old Sep 28, 2007 | 10:31 PM
Thurman's Avatar
Thurman
Depends on what u r going to do with car. Drag race, road coarse, street?
Old Sep 28, 2007 | 10:38 PM
jgallo's Avatar
jgallo
Ill just be using it for the street, i just dont wanna have uneven wear on my tires, should I have an alignment done after there put on?
Old Sep 28, 2007 | 11:03 PM
Mikes_BLK_GT
Yes you'll want an alignment. You'll also need camber bolts for that you can get Eibach camber bolts for about $40. Ishould also consider the rear sway bar as well as an adjustable pandhard bar and brace since lowering will change the geometery. Ford says it's not necessary for thier handling pack but most recommend it. You can also go with lower control arms which help to reduce wheel hop.....
Old Sep 29, 2007 | 09:54 AM
jgallo's Avatar
jgallo
Thanks for the input, I orderd the camber bolts from Eibach, what would you say I need to purchase next?
Old Sep 29, 2007 | 12:11 PM
User 113021's Avatar
User 113021
Personally, I'd go for a minimum of what's in my sig (suspension-wise). But hey, that's just me.
Gene K
Oct 21, 2015 11:37 PM
GimpyHSHS
Sep 18, 2015 12:27 PM
degner122
Sep 16, 2015 07:09 AM
Sep 8, 2015 11:50 AM
raleigh05GTO
Sep 4, 2015 07:09 AM
