Grille question
Old Sep 29, 2007 | 04:14 PM
Rdot9's Avatar
Rdot9
DubStep Stu
Default Grille question
I'm looking to get HID lights and i can only find them forthe GT style fogs, can i get a GT grille and put it inplace of my V6PP grille?
EDIT: and now for your opinion, should i go with a grille like this...
or a standard GT grille???
Old Sep 29, 2007 | 04:20 PM
157dB's Avatar
157dB
Cut & Paste Expert
Default RE: Grille question
No you cant. The GT grill is bigger and wider.
It wont fit. Some say it will but they are the ones trying to
sell you one. Here is a GT grill crammed into my V6 bumper.
Its pointing up at the sky and does not fit correctly.
http://img225.imageshack.us/my.php?image=crammedmu0.jpg
Street Scene V6 to GT Eleanor grill.
http://img406.imageshack.us/my.php?image=img3076gn9.jpg
There are V6 to Gt grills available that take the GT fogs. I have this one and like it.
http://cgi.ebay.com/ebaymotors/05-07...spagenameZWDVW
Some posts on the subject found with the search function:
https://mustangforums.com/m_3225314/tm.htm
https://mustangforums.com/m_697673/tm.htm
https://mustangforums.com/m_697411/tm.htm
https://mustangforums.com/m_384334/tm.htm
https://mustangforums.com/m_3600774/tm.htm
https://mustangforums.com/m_2842165/tm.htm
https://mustangforums.com/m_1050964/tm.htm
Old Sep 29, 2007 | 04:33 PM
Rdot9's Avatar
Rdot9
DubStep Stu
ORIGINAL: 157db
so if i get this i just install it and it's ready to go?
Old Sep 29, 2007 | 04:41 PM
157dB's Avatar
157dB
Cut & Paste Expert
ORIGINAL: Rdot9
ORIGINAL: 157db
No you need to do some wiring but its a piece of cake.
A GT headlight switch will also be needed.
Itgrill justpops rightin andNO horn relocation or
bending of sheetmetal neededas with other V6 to GT
grills that use the stock GT fog locations.
[IMG]local://upfiles/69445/539E9C88CD8949FA9DE0EC4A8ACB7017.jpg[/IMG]
Old Sep 29, 2007 | 04:43 PM
157dB's Avatar
157dB
Cut & Paste Expert
Thiswiring diagramallows for the fogs to be on with the high beams even if they
are off via the fog switchunlike the OEMs that will not be on with the high beams.
The fogs also come on with the high beams when you flash to pass even if they
are not on via the fog switch. They can be wired any way you want them to work.
[IMG]local://upfiles/69445/79C25F8E793C42F6A1072B9DD55BB11A.jpg[/IMG]
Old Sep 29, 2007 | 04:50 PM
Rdot9's Avatar
Rdot9
DubStep Stu
alright, thks
GimpyHSHS
19
Dec 19, 2023 01:12 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
Boostaddict
Lethal Performance
Oct 1, 2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
Oct 1, 2015 08:57 AM
treesloth
Sep 28, 2015 07:03 AM
