hood strut question
Old Oct 7, 2007 | 07:24 AM
300GT's Avatar
300GT
Default hood strut question
I installed Steeda hood struts yesterday. Look good, function great. My concern is that this kit (along with similar struts from CDC and MRT) re-use the 10 mm bolts to attach the struts to the hood hinges and fender wall. Has anyone had a problem with the bolts breaking off under the added stress of supporting the struts? Should I be looking for upgraded 10 mm bolts or will the factory bolts hold up?
Old Oct 7, 2007 | 09:55 AM
PLstang's Avatar
PLstang
Default RE: hood strut question
I installed a set from SHR a few weeks back and never gave it a thought. However, I don't think you'll have an issue with that size bolt and that configuration and load. I wouldn't worry, I'm not.
Old Oct 7, 2007 | 10:17 AM
mlcrycc's Avatar
mlcrycc
I've had my CDC's on for about a year and a half, absolutely no issue. Love em.....
Old Oct 7, 2007 | 10:20 AM
rom8bszfh2cg5q7s4pap's Avatar
I have MRT hood struts as well, so I'd like to know if this is an issue as well. Until someone speaks up about a broken fastener, my concern is minimal. My personal experience has proven that threads of the hole are the weakest link, and not the bolt itself.
Old Oct 7, 2007 | 10:22 AM
Caution's Avatar
Caution
You should be fine -- if you needed the bolts then more then likely they would have came with the kit
Old Oct 7, 2007 | 12:02 PM
300GT's Avatar
300GT
Thanks for the replies. Just wanted to see if anyone had a bolt snap under the load or not. Guess I'll stick with the factory bolts,but I am going to put lock washers onthem. Mine are twisting slightly (the ones that attach to fender)and I'm afraid to torque them down too much. I did a search on hood struts on this forum and someone else had metioned their fender attachments were twisting and that lock washers did the trick.
Old Oct 7, 2007 | 03:17 PM
underbird10's Avatar
underbird10
MRT for over a year with no problems at all....
UB10
Old Oct 7, 2007 | 04:03 PM
Thurman's Avatar
Thurman
Hve mine sitting in a box next to me. When I get it back from the tuner, I will install.
Old Oct 7, 2007 | 04:57 PM
NELS GT's Avatar
NELS GT
Were they easy to install? I do all my own stuff, stripes, shaker, etc... So it wouldnt be an issue, but I dont have much time so the ease of installation may decide whether or not I get them.
Old Oct 7, 2007 | 05:40 PM
300GT's Avatar
300GT
they were easy enough to install by myself, but if I had to do it again I would have someone there to help hold the hood in place when bolting the hood hinges back on. MRT has a pictorial how-to on their website for their hood struts. The Steeda and CDC ones go on same way. Check out the website and judge for yourself how easy you think it would be. Judging from the stuff you did to your car, don't think you'll have any problems whatsoever.
